03-10-2022, 06:51 PM | #1 |
Frame Repair
Is there anyone who can repair a frame that has a plate or two welded where there has been rot? I would like the frame to look original. I suppose one way would be to find a frame section that is good and have it welded. Another way would be if someone could fabricate a piece so that when it's welded it looks original. Either way is ok with me. I live in Massachusetts.
03-10-2022, 07:54 PM | #2 |
Re: Frame Repair
What year are you working on? Attached is a link to a recent discussion on this topic.
https://www.fordbarn.com/forum/showthread.php?t=310691 My car is a 1937 and it has rust through on both sides where the X joins with the side frame rails in front of the rear axle. Besides the areas rusted through, my frame also has rust issues in several areas behind the rear axle. I thought about attempting a repair, but decided instead to replace the frame. |
03-11-2022, 12:09 AM | #3 |
Re: Frame Repair
There are frame pieces available for sale, but I cannot tell you how good they are. I’ve attached pictures of the repair I did on the back of my frame. I couldn’t find a picture of it once everything was welded, welds sanded and new rivets installed, but this should give you an idea or two for repairing your frame.
03-11-2022, 01:20 AM | #4 |
Re: Frame Repair
Out here in Southern California, the biggest danger to our old Ford frames has been from dual exhaust and other go-fast modifications. When these cars had little value, hatchet quality work was quite common. My current '40 project is so clean that I now, more than ever appreciate things authentic and original. At this point, while doing no harm, I allow few select and reversable variations. Those variations can be less than ideal. Perhaps another thread: Fred A
03-12-2022, 12:48 PM | #5 |
Re: Frame Repair
Frame "rot" (rust) anywhere in or on the frame is a hazard. It usually is necessary to do a "body off" inspection to see the damage. A weld on top of rust is likely weak and may fail. It can be done by a shop with extensive experience. At our shop we see amateur welds that are accidents waiting to happen.
03-12-2022, 05:55 PM | #6 |
Re: Frame Repair
03-12-2022, 10:36 PM | #7 |
Re: Frame Repair
Always much easier to repair frames with everything off. I'm not sure a butt weld would be my suggestion on a frame. A Gusset or box of some type would make me feel better. I would think the new buyer would be told it was a welded frame too.
03-12-2022, 11:48 PM | #8 |
Re: Frame Repair
Our '41 frame was butt welded from the factory
03-12-2022, 11:58 PM | #9 |
Re: Frame Repair
You sure?
03-14-2022, 10:11 PM | #10 |
Re: Frame Repair
03-14-2022, 10:13 PM | #11 |
Re: Frame Repair
41? Factory? are you sure?
03-14-2022, 10:27 PM | #12 |
Re: Frame Repair
I'm not saying you can't do it. But if you are going to flip it. I would tell/disclose to the buyer and let them decide. If you are going to butt weld to hide a fault, that's a different discussion.
03-19-2022, 04:12 PM | #13 |
Re: Frame Repair
I've repaired a couple of '40 frames. All the ones I see have rot at the kick up in front of the right rear wheel. The right side is next to the shoulder of the road, so junk gets thrown up into the holes in the frame and it rusts through. I'd say I have average welding skills with gas or mig. A proper butt weld with good penetration should be as strong as original and can be ground down to be invisible. Anyway, here are some photos of one repair.
03-19-2022, 04:30 PM | #14 |
Re: Frame Repair
I also have issues in the same spot on my 40. I have found two suppliers of "boxing plates". Streetrod Engineering and Wolfe's Metal Fabricators. They have them in sections. There are probably others that have similar products.
03-19-2022, 04:59 PM | #15 |
Re: Frame Repair
Joe's Antique Auto Parts in Massachusetts has repair sections.
03-20-2022, 12:44 PM | #16 | |
Re: Frame Repair
That's nice work. I certainly would not be afraid of that repair. Well done! Terry
