Old 07-10-2019, 12:46 PM   #1
VeryTangled
VeryTangled's Avatar
Default 1935 1936 Inside Door or Window Handle Tool
Hi Everyone. I need to put in the springs and pins that hold the door and window handles onto the inside of my '35. Some previous owner, or their upholstery shop, removed them and tossed them away. I have the replacement parts ready to go back in.
I have seen somewhere on the FordBarn a tool that made this job a breeze. I can't seem to dig up the thread that included a photo.
I remember it had a protruding pin, and a couple of fork-like pieces. The forks were used to depress the escutcheon (and spring under it) and the protruding pin would either push the handle locking pin in or out for assembly or removal of the handles.
Anybody remember the tool I'm thinking about?
Thanks in advance.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 07-10-2019, 01:01 PM   #2
Darrell S
Darrell S's Avatar
Default Re: 1935 1936 Inside Door or Window Handle Tool
https://www.ebay.com/itm/1932-48-For...wAAOSwSrNZ7m91
Darrell S is offline   Reply With Quote
Old 07-10-2019, 02:53 PM   #3
VeryTangled
Thanks very much Darrell, I see this is being listed by 3rd Generation Automotive too! Bonus.
The one I remember seeing here on the 'Barn seemed to be white plastic.
-Jeff H
Old 07-10-2019, 05:00 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
This is the tool that I have had since the early '50's.
Old 07-10-2019, 05:09 PM   #5
VeryTangled
Thanks 51 Merc-CT, That's the gizmo I was visualizing!
If you've had it since the early '50's, then its a good bit older than me!
-Jeff H
Old 07-10-2019, 07:53 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I've removed and installed lots of '35-'36 inner door handles over the years and don't recall ever needing a special tool like the ones shown here.
Old 07-11-2019, 04:24 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Totally agree that a special tool is not needed (have done many without it) but it makes it simpler.
Old 07-11-2019, 09:13 AM   #8
blucar
blucar's Avatar
A small drift punch works just fine once the trim ring is pushed back.
Bill.... 36 5 win cpe
Old 07-11-2019, 09:40 AM   #9
JM 35 Sedan
Roger that. That's all I've ever used.
Now maybe on an assembly line, having that tool during the assembly procedure, might be an advantage.
John
Old 07-11-2019, 05:09 PM   #10
VeryTangled
The pins are very loose in my handles, that don't have springs yet.
I actually lost a pin in the grass today as I was fiddling with things, it just dropped to the ground as soon as I moved the escutcheon. Found it after waving a magnet in the grass around for a minute or two. The drivers door handle pin lost itself the same way & I've been using a paper clip in there for a few weeks.
It doesn't look like a terrible job, but I'm always looking to work smarter not harder.
-Jeff H
Old 07-11-2019, 05:23 PM   #11
19Fordy
19Fordy's Avatar
I made one out of PVC years ago.
https://www.fordbarn.com/forum/showt...e+removal+tool
Old 07-11-2019, 06:18 PM   #12
VeryTangled
Originally Posted by 19Fordy View Post
Here's the wicked cool tool from 19fordy, might try this if things get dicey.
-Jeff H
Old 07-25-2019, 08:01 AM   #13
einstein
Mac's ( Ekler) sells the tool it's $35 heres the part # TOOL-46250
einstein is offline   Reply With Quote
Old 07-25-2019, 08:36 AM   #14
tubman
tubman's Avatar
Originally Posted by einstein View Post
Mac's ( Ekler) sells the tool it's $35 here's the part # TOOL-46250
When I looked that up, I see the price is now $39.95. No wonder I don't buy stuff from them any more. What the hell is going on with prices? This is a simple metal tool that probably costs less than a buck to make. If I needed one, I would make my own rather than spending this kind of money. It's insane.
