Old 11-09-2020, 07:06 PM   #1
1crosscut
1crosscut's Avatar
Default Glue for generator wire wrap.
In Les Andrew's red book it states that one should wrap bare wires with a cotton thread and seal it with a heat resistant glue but doesn't say what glue to use. I've done searches on the Ford Barn site and on the web and haven't found any reference to a glue for this use.
What have you used?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-09-2020, 07:51 PM   #2
GPierce
GPierce's Avatar
Default Re: Glue for generator wire wrap.
Glyptal is used to insulate and protect most motor winding and generator armatures.
It is also used on cast iron to smooth the rough surfaces such as valve chambers to speed oil return.
http://www.glyptal.com/
https://www.electro-wind.com/glyptal...can-361-g.html
File Type: jpeg D00FAB50-6AC8-4EFB-AAE7-91AFA4E52018.jpeg (6.9 KB, 8 views)
GPierce is offline   Reply With Quote
Old 11-10-2020, 09:47 PM   #3
1crosscut
1crosscut's Avatar
Thank you.
Old 11-10-2020, 10:18 PM   #4
David R.
I used linen string and painted it with red insulating varnish
David R. is offline   Reply With Quote
