Old 09-03-2020, 06:56 PM   #1
nhusa
nhusa's Avatar
Default Garage lights
I had 15 4 tube florescent lights in my 2+ car garage to give me light for working on vehicles.
A few weeks ago I decided that to convert to LEDs.
After a bit of research I choose a 9600 80 watt Led light with adjustable panels to replace 4 sets of lights and installed it.
I was amazed at the amount of light and ordered 5 more to replace the remainder of the florescent fixtures.
The light in the garage is significantly better than before and it costs less to run them.
The current joke is for the last person out of the garage is required to turn the sun off.
The biggest issue was to dispose of the old fixtures and florescent 60 tubes.
nhusa is offline   Reply With Quote
Old 09-03-2020, 07:00 PM   #2
blgitn
blgitn's Avatar
Default Re: Garage lights
That sounds great!
Can you post a picture of the replacement units?
R/ Roger.
blgitn is offline   Reply With Quote
Old 09-03-2020, 07:11 PM   #3
McMimmcs
McMimmcs's Avatar
What was total cost and have you calculated what electrical savings will be ?
McMimmcs is offline   Reply With Quote
Old 09-03-2020, 07:21 PM   #4
Charlie Stephens
I found the best price at Costco. Their lights were made by Feit electric. Savings are dependent upon how much time you spend in the garage. I replaced all of the lights in my house and garage and the electric bill dropped about 30%.
Charlie Stephens
Old 09-03-2020, 07:25 PM   #5
jm29henry
jm29henry's Avatar
If your lamps have green end on the end of your tubes that means that they are eco friendly and can be disposed in you trash .as for the ballast if they are electronic they would not have PCB’s and also could be thrown in your trash best of luck to you
jm29henry is offline   Reply With Quote
Old 09-03-2020, 07:36 PM   #6
McMimmcs
McMimmcs's Avatar
Charlie Stephens
That is what I was looking for, percentage. A very significant savings for sure!
Old 09-03-2020, 07:49 PM   #7
Synchro909
Synchro909's Avatar
As part of the move to low energy use (and hence carbon emissions), our Government has been changing over any old incandescent or fluorescent lights for the low energy consumption LED replacement free of charge to the home owner. I agree - for a fraction of the energy, lightis much better. There is the cold bluish light and the warmer more yellow light. We take our pick.
In the workshop, they have proved to be a wonder but I still prefer to work on the car just inside the open roller door where I can see our resident King Parrots, Rosellas, Magpies, Kookaburras etc. It makes working on the car a pleasure.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-03-2020, 08:51 PM   #8
MVal
A good friend installed LED lights in their kitchen which I believe were the tube type. During an outage (we have a lot of those in CA) when his generator was running his wife called him to the kitchen because smoke was coming from several of the lights. They called the local fire department and after resolving the issue they told him some of the LED's can be a problem when using a generator. Evidently on the cheaper stand by generators the sine wave isn't very good and it causes the lights to heat up and smoke then start smoldering, etc. I haven't had a problem personally but am using a Honda generator which has a near perfect sine wave. Only saying this as an issue to consider when using LEDs and a generator and am assuming the FD personnel know what they are talking about!
MVal is offline   Reply With Quote
Old 09-03-2020, 09:27 PM   #9
daren007
Do not throw ballast in the garbage. Take them to your local metal recycler.
daren007 is offline   Reply With Quote
Old 09-04-2020, 03:30 AM   #10
Ak Sourdough
Ak Sourdough's Avatar
I replaced the 4' florescents in my shop with LEDs from Amazon. These were the most lumins per dollar I could find at the time. Bought two boxes of 25 and used most of them.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Current draw went from just over 27 amps, to right around 10 amps and the increase in light is amazing.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 09-04-2020, 08:34 AM   #11
1928Mik
1928Mik's Avatar
I had two sets of 8 ft high output T-12 Florescents in my home garage and swapped them out for 8 4ft LED shop lights from Rural King on sale for 19 bucks each. Made a HUGE difference in light output and amp draw. Luckily I have a dumpster at work for the old fixtures and bulb disposal.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 09-04-2020, 11:44 AM   #12
Swingle
Switched my shed lights over from Florescents to the LED's a few years back.
First thing I noticed is that they are much brighter, but tend to throw a different shadow - hard to explain.
Second thing noticed is they start out bright, even when they are cold. The Florescents, if it is below 30, they go into dim mode until they warm up.
The third and big thing I noticed with the LEDs is that I am not replacing them each year. With the Florescents they would last about a year - 40x60 shed, get out the tall ladder, work your way around the cars and toys, change bulbs.
How much money am I saving? Cannot give an exact amount, but can see the difference in the electric bill.
Swingle is offline   Reply With Quote
Old 09-04-2020, 11:54 AM   #13
Smooth_One
Smooth_One's Avatar
I’m replacing four fluorescent panels with four LED panels in the next couple of weeks in mine.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 09-04-2020, 05:18 PM   #14
Big hammer
LEDs are great, now. If someone wants good lighting during the day with the electric meter not spinning , look at solar tubes lighting.
get a bigger hammer tap done
Old 09-04-2020, 06:07 PM   #15
warhorseracing
warhorseracing's Avatar
I replaced all of the fluorescent 4' lights with 4' LED's from Rural King,$19 on sale on the top floor which is where I mainly work from. I placed the old fluorescent lights in the basement level of the garage and replaced all incandescent lights in the house basement and garage. The LED's are so much brighter, start out bright when winter hits, (I heat the shop at 50 Degrees F.) and no more buzzing from the ballast.
warhorseracing is offline   Reply With Quote
Old 09-04-2020, 08:16 PM   #16
mhsprecher
mhsprecher's Avatar
For getting rid of the old lights, if you have a local Craigslist, someone will take them off your hands.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 09-04-2020, 08:33 PM   #17
jw hash
jw hash's Avatar
i switched over to LED in my house,garage, and shop including the paint booth. it is nice to turn on the lights and all of them come at the same time. and they don`t hum like the fluorescent`s.
jw hash is offline   Reply With Quote
Old 09-05-2020, 01:33 AM   #18
Bill G
Bill G's Avatar
I have about 12 4' LED fixtures, a mixture of Harbor Freight and Home Depot house brands. They REALLY light up the garage and I can really see what I am doing. Really a blessing. Now, when I go to other's shops, they seem dark. I can also say that it can be annoying when I am under the car laying on my back looking up. If the bright light shines in my face, it's hard to see what's under the car. But I like having the light and it doesn't break the bank either for the cost of the fixtures or the power to run them.
Bill G is offline   Reply With Quote
Old 09-05-2020, 09:04 AM   #19
Licensed to kill
Licensed to kill's Avatar
I had 8-4 tube T5 fluorescent fixture in my shop. They were state of the art in shop lighting at the time and were quite good. Several years ago I replaced them with 4-250 watt LED's. HUGE difference but in my case, no power savings. Power consumption is about the same. I had the LED guy come out with samples and I huge 1 of the 250's in the middle of the shop temporarily just to see and the one light lit up the shop better than the 8 T5's.
Licensed to kill is offline   Reply With Quote
Old 09-05-2020, 12:38 PM   #20
2935ford
2935ford's Avatar
If you want to save a little money, you can convert your current flo fixtures to LED with a simple rewire of the tombstones and no more ballasts. LED's just need power from one end like a normal light bulb. So, all you have to purchase is the LED tube.
2935ford is offline   Reply With Quote
