Old 06-01-2020, 09:18 PM   #1
corsair_kid1979
corsair_kid1979's Avatar
Default Universal Joint Removal
So I just started taking apart my three-speed Ford toploader transmission and I cannot figure out, for the life of me, how to remove the universal joint from the back of the transmission. Can anyone advise me if I am missing something?
corsair_kid1979 is offline   Reply With Quote
Old 06-01-2020, 09:20 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Universal Joint Removal
It is bolted on.
Old 06-01-2020, 09:26 PM   #3
corsair_kid1979
I have removed the bolt, but it won't come off. Figured there was something else I was missing.
Old 06-01-2020, 09:41 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
It's stuck! With the bolt out, pry it off! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-01-2020, 11:06 PM   #5
corsair_kid1979
Little heat and she popped right off. For the clutch shaft removal, do you grind off the clutch fork pin and slide the shaft out?
Old 06-01-2020, 11:47 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Yup! Grind the head and punch the pin out! DD
T5 W/TORQUE TUBE
Old 06-02-2020, 05:12 AM   #7
Kerk
Be suree to save the special Thick washer that heldd thee U joint on, See previous posts on this. JMS kerk
Kerk is offline   Reply With Quote
Old 06-02-2020, 12:48 PM   #8
A bones
A bones's Avatar
If laying rusty, penetrant, and a little torment with a hammer, take your time you're not sticking a nail into wood. Give the oil time to creep into the rust. Good luck. Welcome Neighbor.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-02-2020, 05:23 PM   #9
GaryU.
GaryU.'s Avatar
Get the book, from the master Mac Van Pelt. Everything you need to know.
http://www.vanpeltsales.com/FH_web/f...trans-book.htm
GaryU. is offline   Reply With Quote
