Old 02-27-2020, 10:21 AM   #1
wbs
Default starter motor
hello - i am trying to figure out how to check ohms on field windings with just removing the band around motor and not disassembling end plate. probably no one knows the answer but does anyone know if windings are series, shunt or compound?
wbs is offline   Reply With Quote
Old 02-27-2020, 11:46 AM   #2
katy
katy's Avatar
Default Re: starter motor
Going by this starter parts drawing I would say that they are connected in series, but with the heavy winding the ohmage will be very low.
Old 02-27-2020, 11:52 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
the fields split at the post, each goes through 2 field coils to its brush---through the armature to ground through 2 brushes---it is considered s series wound motor
your meter due to the size of the winding is best used to detect shorts, though I like a 110 volt test light better----the shorted area smokes and usually cleaning and insulating there will return the windings to function ----the 'wire" is so heavy it rarely fails open, shorting to ground is more common,
Old 02-27-2020, 12:14 PM   #4
30 Closed Cab PU
For a very rough guess 6v/60 amps, windings at the terminals = .1 ohms. Way to low to measure with a meter. Variances in probe connection, lead contact at the meter, etc. will throw readings that small off.
30 Closed Cab PU is offline   Reply With Quote
Old 02-28-2020, 08:17 PM   #5
wbs
thanks as always to those that reply-i will take any advice to heart
Old 02-29-2020, 07:36 PM   #6
barkleydave
barkleydave's Avatar
Amp draw is more informative. You can expect minimum of 60+ amps starting draw on a 6 volt system. Now your starting draw does not go through your amp meter it would burn it up quick! Cold morning start can easily exceed 100+ amps. Now you can reduce the amp draw by half if using a 12 volt system.
barkleydave is offline   Reply With Quote
Old 02-29-2020, 08:10 PM   #7
Synchro909
Synchro909's Avatar
This was a topic that came up in a recent thread. I pointed out and still maintain that when you convert to 12 volts, the amperage doubles, not halves.
The resistance of the starter motor does not change but the voltage across it is doubled, therefore the amps double and the power goes up four fold.
R=V/I. resistance (R) is constant so if you double the volts (V), the current (I) has to double also.
P=VxI With both volts and current doubled, the power (P) is quadrupled. That's why an unmodified 6v starter running on 12v will spin so fast.
The amps drawn can be reduced by increasing the resistance of the starter. I do that by connecting all of the field windings in series, then taking a lead to the brushes. The effect of that is to quadruple the resistance of the fields but the resistance of the armature hasn't been changed so the starter runs at higher speed but not so much as it would without modification. It runs at about what a 6v starter would on about 8-9 volts, I estimate.
Using small, long cables also helps.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 03-01-2020, 08:38 AM   #8
30 Closed Cab PU
Syncro - Also insure/upgrade to modern Bendix, or is the old style Bendix OK with this modification of field wiring?
Old 03-01-2020, 10:05 AM   #9
CT Jack
CT Jack's Avatar
Synchro909 you are right on mate. The physics and the data say it all. The rule of thumb is keep your engine and system components properly maintained and it will always start with 6 volts. I have a 6 volt solid state ignition system in my A and it usually requires 1 - 2 rev's to start for a cold start.
CT Jack is offline   Reply With Quote
Old 03-01-2020, 10:31 AM   #10
The Master Cylinder
The Master Cylinder's Avatar
While I understand what your saying what I don't understand is if the draw is doubled why do 12v systems use smaller gauge wire?
I read somewhere that one of the reasons car manufacturers went with 12v systems (besides the obvious) is that they would save $$ by using smaller copper wires.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-01-2020, 12:16 PM   #11
katy
katy's Avatar
Because they're designed for 12 volts. Using 12 volts on a 6 volt system is a whole different kettle of fish.
Old 03-01-2020, 04:53 PM   #12
Synchro909
Synchro909's Avatar
I've used both quite successfully. FWIW, it is the huge impact of the bendix hitting the ring gear that causes trouble when 12v is applied to an unmodified 6v starter. My mod reduces that.
Old 03-01-2020, 04:54 PM   #13
Synchro909
Synchro909's Avatar
Katy, you are dead right. The starter designed for 12 volts has a higher internal resistance than one designed for 6 volts.
