Old 03-03-2018, 10:47 AM   #1
michael a
michael a's Avatar
Default Dual carburetors
Is there a good information site where it explains to you how to sync these carburetors any help would be greatly appreciated thank you in advance
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 03-03-2018, 11:03 AM   #2
drolston
drolston's Avatar
Default Re: Dual carburetors
The instructions that come with the carb synchronizer (the one with the bead in the tube) are pretty good.
Old 03-03-2018, 11:12 AM   #3
adileo
adileo's Avatar
Agree available on eBay;
File Type: jpg 7AE35E6C-E316-45CD-997F-813393494E2F.jpg (9.7 KB, 32 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 03-03-2018, 11:31 AM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I like this sync tool better than the old style ball type. Works really well....
https://www.ebay.com/itm/Empi-Univer...5aA6m7&vxp=mtr
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-03-2018, 01:12 PM   #5
Terry,OH
Terry,OH's Avatar
It is VERY simple. your going to adjust the idle RPM adjustment so both Carbs. draw equal venturi vacuum as measured with either of the two devices as shown above at idle. In effect both Carbs. will contribute equally to idle. If when this is done idle adj is too high than lower the idle adj. on both equally for your desired RPM then recheck and readjust. If you adjust idle mixture and the idle RPM changes, then again readjust the sync.
Old 03-04-2018, 09:03 AM   #6
john in illinois
john in illinois's Avatar
Also the throttle linkage needs to be loose. tighten after synching.
John
john in illinois is offline   Reply With Quote
Old 03-04-2018, 09:48 AM   #7
Terry,OH
Terry,OH's Avatar
John is correct, disconnect the linkage connecting the two carbs together, before starting and replace when done. If you don't then a adjustment on eather carb RPM would effect the other.
Old 03-04-2018, 11:09 AM   #8
V8 Bob
V8 Bob's Avatar
The very first thing to do is make sure the two carbs are exactly the same, including jetting, PV, and float settings, assuming the normal straight linkage settup. If the carbs have no history or questionable assembly, run each carb on a stock intake and monitor vacuum levels during idle bleed and rpm adjustments, which should match. This will ensure the carbs will easily sync and run trouble free on the dual intake.
V8 Bob is offline   Reply With Quote
Old 03-04-2018, 05:27 PM   #9
Ol' Ron
Ol' Ron's Avatar
Before the invention of all these tuning aides, we used to set the idle screws by running our hand over the carbs, until l they were both the same. Simple and effective,
Old 03-04-2018, 07:17 PM   #10
uncle max
uncle max's Avatar
Along the same way of thinking... The idle mixture screws can be adjusted nicely by cutting a two foot length of vacuum hose, stick one end down the carb and the other end in your ear. Moving the end in the carb from side to side and listening for the same exact percolating/hissing sound while adjusting the screws and you're there!
Works great for removing earwax in the event of a backfire as well!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-05-2018, 08:19 AM   #11
scicala
scicala's Avatar
Thanks Max and 'Ole Ron,
I love these old simple and effective tricks to diagnose and tune.
Sal
Old 03-05-2018, 07:46 PM   #12
Talkwrench
Talkwrench's Avatar
Hahaha more like removing your ear!
Im for a synchroniser and a vacuum gauge.. (and maybe the wisest move going back to a single carb ; )
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-06-2018, 02:58 AM   #13
expavr
expavr's Avatar
“Works great for removing earwax in the event of a backfire as well!”
������ You missed your calling as a standup comedian....
expavr is offline   Reply With Quote
Old 03-06-2018, 07:17 AM   #14
chap52
chap52's Avatar
Search "unisync" on this site, lots of info.
I use a unisync because after all of these years of developing my "selective hearing" I left the hissing frequency out, Chap
chap52 is offline   Reply With Quote
Old 03-06-2018, 07:21 AM   #15
prpmmp
https://www.jalopyjournal.com/forum/...c-tech.124624/ Pete
prpmmp is offline   Reply With Quote
