07-25-2017, 10:41 AM | #1 |
Mystery Water Pump?
Hi folks,
I'm in the process of a frame-up restoration of a 1929 couple and I started on the water pump today. To my surprise, I found a housing I'm not familiar with that looks thinner and doesn't have the hole in the side of housing like a normal pump. Any insight on what this pump is, and whether it's worth rebuilding? Thanks in advance for your help. Pat |
07-25-2017, 11:02 AM | #2 | |
Re: Mystery Water Pump?
07-25-2017, 11:13 AM | #3 | |
07-25-2017, 11:25 AM | #4 |
Thanks Brent! Looks like the same one. I appreciate your help.
07-25-2017, 04:29 PM | #5 |
I have one like that on my roadster too. I haven't had any issues with it for more than 20 years.
07-25-2017, 04:48 PM | #6 |
07-25-2017, 11:39 PM | #7 |
I've had one on my Coupe for 30 years. No problem. Have a couple that leak and would like to find someone who can rebuild them? Where can I find new seals? One definitely needs a new shaft,,,,,,,
10-07-2017, 08:00 PM | #8 |
Those were produced by a gentlemen in Kentucky back in the 70-80's. I can't recall his name anymore but they were excellent pumps. I may still have one around somewhere
Larry Shepard |
10-07-2017, 08:14 PM | #9 |
Brent, you don't need a fan on your speedster?
10-08-2017, 06:13 AM | #10 |
I just remembered his name . Bill powers. He passed away many years ago.
Larry |
10-08-2017, 07:46 AM | #11 |
Is that a spring loaded seal, inside the impeller?
Bill ????
10-08-2017, 01:15 PM | #12 |
You can get a new seal at a swiming pool pump repair shop, as I remember it is seal #1. Be sure to polish the seal area on the pump frame.
jb
Connoisseur of Rust |
