08-17-2016, 02:03 AM | #1 |
7 tooth steering box turns not equal right to left
I have been racking my brain (or whats left of it) for 6 hours tonight trying to get equal turns out of my re-built 7 tooth steering box. Am I missing something? I have tried everything I can think of. I have had it back apart 6 times with no change. I get a little more than 1 1/4 turns to the left and 1 turn to the right.
Any suggestions? Should I just leave it alone? Is that the way they are? Never paid much attention before as the thing was totally shot with almost a full 1/4 turn of slop. It could have been that way before I just don't know. It's driving me crazy. Thanks Marc |
08-17-2016, 09:14 AM | #2 |
Re: 7 tooth steering box turns not equal right to left
Do you have the short Pittman arm?
08-17-2016, 10:38 AM | #3 |
A 1/4 turn variation is not much.
I think you are seeing the slack in the meshing gears when you change directions.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
08-17-2016, 10:38 AM | #4 |
I have a stock Pittman arm. After sleeping on it I think my drivers side steering arm is bent. When I got the car the axel was back about an inch on the drivers side. I changed the axel but did nothing with the steering arm.
08-17-2016, 10:42 AM | #5 |
The symptom points to the car having a shortened pitman arm, when the steering turns to the right the sector contacts the inside of the steering box housing and not the steering stop, either a adjustable drag link or use the stock arm will fix it, I made a adjustable link for my Double A, which needs all the help you can get when turning.
I just posted this and saw your comments about the left steering arm and that you have the stock pitman arm, go with the steering arm.
Nothing can be made foolproof, ---- fools are ingenious bastards. Last edited by Brian T; 08-17-2016 at 02:36 PM. Reason: Added text |
08-17-2016, 11:06 AM | #6 |
08-17-2016, 11:17 AM | #7 | |
08-17-2016, 02:57 PM | #8 | |
I have often wondered if the venders that re-ball these steering arms place then in a jig and check to see how close they are to factory specs.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
08-17-2016, 04:01 PM | #9 |
he says he has a stock arm #4
'31 180A |
