Old 11-06-2013, 11:00 PM   #1
paleot
Default Offenhauser Heads
I just bought a set of offy heads stamped 375 anyone have any Idea what the compression ratio may be?
Tony
paleot is offline   Reply With Quote
Old 11-07-2013, 01:14 AM   #2
jr9162
Default Re: Offenhauser Heads
The heads have 57 cc combustion chambers. Used on a stock 239 w/no relief the CR will be ~8.41:1, with a relief ~8.09:1. The CR will increase as the bore size increases. In a 255 (Merc) you're looking at ~8.90:1 with no relief, and ~8.56:1 with a relief. The reliefs quoted above would be .0100" and gaskets above would be at 0.057" thick. John
jr9162 is offline   Reply With Quote
Old 11-07-2013, 08:42 AM   #3
Ol' Ron
Ol' Ron's Avatar
Best to measure them, the casting can be all over the place. The 375was for Valve lift, but this didn't clear the Max #1 in most cases with out some clearancing.
Old 11-07-2013, 09:27 PM   #4
paleot
Thanks John and Ol' Ron info will be a big help. Ron I am planning on running a Winfeild ¾ Cam do you think I will have valve clearance problems?
Old 11-07-2013, 09:35 PM   #5
Ol' Ron
Ol' Ron's Avatar
That's impossable to answer. Depending on the net lift and if the heads have ever been milled. are they new or used.
Old 11-08-2013, 10:17 PM   #6
paleot
Used, but they don't look to be milled at all. I will fit up a couple of valves and guides and check my clearance what is safe?
Old 11-08-2013, 11:25 PM   #7
Ol' Ron
Ol' Ron's Avatar
.050" over pistons and the valves should clear, for a street engine the valve clearance isn't that important. the closer the higher the CR
Old 11-08-2013, 11:35 PM   #8
paleot
Thanks a bunch Ron I will mock it up and check in the morning.
Tony
