Old 05-19-2014, 12:05 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Old problem revisited, rough running 8BA
8BA ran great on engine stand but not since installed in car. Distributor and carb. are working as they should and think problem lies elsewhere. Changes since engine was on test stand are the following: 12V battery that was on engine stand is now located behind rear seat with double 00 positive cable (engine starts immediately) had on/off toggle switch for ignition switch on test stand, am now using stock '36 ignition switch, start button on engine stand was more heavy duty than the one now mounted in my dash and now have added two fuse panels, one hot all the time, the other switchable and a 50 amp circuit breaker. The ignition switch is wired directly to the battery and not going through fuse panel. Have also added engine to ground strap. Car has negative ground and is equipped with alternator with internal regulator. Compression and vacuum good and plugs look good. No crossed plug wires. Any ideas?
36tudordeluxe is offline   Reply With Quote
Old 05-19-2014, 12:27 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Old problem revisited, rough running 8BA
Maybe a little more info as to how it runs? Is the problem at idle, driving, acceleration. We are not mind readers.
Old 05-19-2014, 03:30 PM   #3
36tudordeluxe
Won't idle, runs rough at all RPM's under no load conditions, un-driveable. I know I'm in the wrong venue for mind readers, will try harder.
Old 05-19-2014, 03:43 PM   #4
corvette8n
corvette8n's Avatar
Vacuum leak?
Old 05-19-2014, 03:55 PM   #5
Ross F-1
Ross F-1's Avatar
I think your assumption that the distributor and carb are working as they should is a bad one. I'd suspect distributor first. Is it stock?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-19-2014, 04:19 PM   #6
George/Maine
George/Maine's Avatar
Make sure you have the correct coil and resister for 12 volts.
Then wire direct to resister wired to coil.
if it runs good your problem is all the mickey mouse wiring.
George/Maine is offline   Reply With Quote
Old 05-19-2014, 04:28 PM   #7
40cpe
40cpe's Avatar
If I remember right, the first problem was because of bent rods in the carb and new ones were on order. At that time the idle was fine, and ran bad above idle. Bubba had checked your distributor to be fine. You have been tutored on how to time it. As already mentioned, verify good voltage to coil, Unless you have a new carb on it, I would look there.
40cpe is online now   Reply With Quote
Old 05-19-2014, 04:53 PM   #8
George/Maine
When you say you have no crossed wires there is a Motors manual and the firing order is wrong,
You may want to check it with Mercury v8 49 to 53
I had it happen to me.
Old 05-19-2014, 05:49 PM   #9
i'maquadriplegic
is it misfiring or is it a vibration you're feeling?
i'maquadriplegic is offline   Reply With Quote
Old 05-19-2014, 07:00 PM   #10
36tudordeluxe
That's interesting, am using the firing order as found on the VanPelt site; will look into this further. The carb. is a new Edelbrock with new metering rods installed, this solved my over rich condition that was fouling the spark plugs. The Mallory electronic disturb. has been gone through by Bubba's and is in good working order; Bubba supplied the correct matching coil. Firing order am using is 15486372. The problem seems more like a misfire than a bad vibration.
Old 05-19-2014, 07:05 PM   #11
36tudordeluxe
Originally Posted by corvette8n View Post
Vacuum leak?
No vacuum leak between manifold, adapter & carb, all three ports on the carb. are blocked off. Vacuum measures 17" which am told is about right for the cam (L-100) am using.
Old 05-19-2014, 07:15 PM   #12
36tudordeluxe
Have 12.6V at the battery and only 9.7V at the coil with no resistor, that can't be good!? Bubba also supplied correct resistor but said only to use it if coil overheats.
Old 05-19-2014, 07:31 PM   #13
George/Maine
If you by passed and went to coil direct you should have 12 colts.
Some times when going to 12 volts the resister under dash is still in use.
Old 05-19-2014, 07:35 PM   #14
36tudordeluxe
No resistor under the dash, have replaced all wiring and therein lies the problem I think. Will explore why I'm not getting 12V at the coil with ignition switch on. Thanks everyone for the help.
Old 05-19-2014, 07:36 PM   #15
jan bogert
jan bogert's Avatar
ballast resister, your melting down the coil
jan bogert is offline   Reply With Quote
Old 05-19-2014, 07:48 PM   #16
flatjack9
flatjack9's Avatar
Maybe, maybe not. What are the specs for voltage at the coil with the Mallory? What about plug wires?
Old 05-19-2014, 09:31 PM   #17
36tudordeluxe
Have Taylor 8mm spiro wires. Will find out what the voltage should be to the coil from Bubba, am wondering why I don't have 12V at the coil. Will investigate tomorrow.
Old 05-19-2014, 09:58 PM   #18
Ross F-1
Ross F-1's Avatar
The voltage at the (+) terminal on the coil should be 12v or whatever the battery is at; the voltage at the (-) terminal would be dropped by the coil resistance if the points are closed.
You said "Have also added engine to ground strap." The negative battery cable should be going to the block or trans bellhousing. Is that how you have it?
Old 05-19-2014, 10:21 PM   #19
Bill OH
I would clean the contacts in the stock ignition switch. You have 12 volts to the switch and 9 volts after the switch?
Bill OH is offline   Reply With Quote
Old 05-19-2014, 10:55 PM   #20
Planojc
Planojc's Avatar
I agree with Bill. Voltage drop thru the ignition switch. Place a jumper across it and see if it comes up to 12v.
Planojc is offline   Reply With Quote
