Old 10-27-2020, 10:13 AM   #1
barkleydave
barkleydave's Avatar
Default AA 1930 king pins bushings needed
Looking for source for set of AA 1930 king pins and bushings
Thanks
barkleydave is offline   Reply With Quote
Old 10-27-2020, 11:03 AM   #2
Ernie Vitucci
Default Re: AA 1930 king pins bushings needed
Good Morning...You might try Arizona Model A...Sammy Guthrie...480-782-0266. He might have good used ones...or NOS...Ernie in Arizona
Old 10-27-2020, 11:18 AM   #3
David R.
Snyders has the bushings, the pins a little harder, nos if you can find them.
David R. is offline   Reply With Quote
Old 10-27-2020, 02:50 PM   #4
Paul Mike
Paul Mike's Avatar
I would call Steve ar Berts.
Paul Mike is offline   Reply With Quote
Old 10-27-2020, 03:14 PM   #5
J Franklin
J Franklin's Avatar
Many times it is only the bushings that are needed.
Old 10-27-2020, 08:28 PM   #6
Reds34
I had gotten some bushings from TAM'S a number of years back.
Red Wolf
Reds34 is offline   Reply With Quote
Old 10-27-2020, 10:53 PM   #7
Bill Cilker
Bill Cilker's Avatar
Dave
I have a NOS set that I can sell to you.
$100 plus shipping.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 10-28-2020, 06:02 AM   #8
David R.
I found a nos set at a swap meet that I think were WWII era. They didn’t have any shims and were marked wrong as to left and right. My original thrust bearings cleaned up and looked better than the ones in the set so I used them. (They were roller bearings and the replacement were ball) I found some shims from one of the on line supply places. I used Snyder’s bushings. They were better than the WWII ones and had the correct grease grooves. Grainger has a thrust bearing that I think would work but since my original ones cleaned up good I didn’t order them. I had a local truck spring shop ream the bushings.
Old 11-02-2020, 10:53 AM   #9
barkleydave
Originally Posted by Bill Cilker View Post
Dave
$100 plus shipping.
Thanks Bill for helping my Nephew with the King Pins for his AA!
Model A folks are the best for jumping in to help others!
