Old 10-19-2020, 02:49 PM   #1
Scshelton9105
Default 1940 Ford Convertible Top Frame shoulder bolts
Does anyone have a source for the 1940 convertible top frame shoulder bolts? I especially need to find the two smaller ones that attach the rear steel bow to each side of the top frame. The shoulder diameter is 3/8”. Thread size is 5/16-18. About an inch long or so. See pic.
File Type: jpeg 49145461-7C6D-4525-BBE3-C0E6D09EB9B1.jpeg (91.6 KB, 37 views)
Scshelton9105 is offline   Reply With Quote
Old 10-19-2020, 05:43 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1940 Ford Convertible Top Frame shoulder bolts
If you can't find them, you could make some by turning down a 3/8 dia. stainless bolt on a lathe and then cut new threads. I have had success doing that.
19Fordy is online now   Reply With Quote
Old 10-19-2020, 06:08 PM   #3
rg130
rg130's Avatar
Totally Stainless should have what you need. They make convertible top bolts along with many other products including various kits. Excellent quality.
http://www.totallystainless.com/
rg130 is offline   Reply With Quote
Old 10-19-2020, 08:20 PM   #4
Scshelton9105
Thank you for all the replies. Much appreciated!
Old 10-19-2020, 09:53 PM   #5
deuce_roadster
deuce_roadster's Avatar
I might have an original, I will look. I used to have a 40 Convertible. Will PM you if I do.
Old 10-20-2020, 07:08 AM   #6
Scshelton9105
Fantastic. I would appreciate that very much.
Old 10-20-2020, 11:38 AM   #7
blucar
blucar's Avatar
I had to have the top iron bolts made for my '39 conv. Originally they were chrome plated, the replacements I found did not have the correct shoulders and the heads were small. I had a machine shop make the bolts out of stainless steel then I polished the heads.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 10-20-2020, 12:40 PM   #8
Karl Wescott
Karl Wescott's Avatar
Here are scans from an original 1940 parts book showing the various shouldered bolts used on 1940 Ford (model 66) and Mercury convertible (model 76) and convertible sedan (model 74).
I would be careful with Totally Stainless, While their quality is superb their interchange is suspect as their catalog lists 1939-40 convertible... the two years are different. Compare the specs of what you need to what you have.
Karl Wescott is offline   Reply With Quote
Old 10-20-2020, 06:10 PM   #9
Scshelton9105
Thank you for the advice. Tried to reply earlier and describe an alternate approach that I took. Bought two chrome bolts and a 3/8 OD steel fuel line, which is 5/16 ID. I cut 1/2” lengths of the tube which acted as sleeves or shoulders for the bolts. Worked perfectly.
Old 10-20-2020, 08:52 PM   #10
deuce_roadster
I do have some original bolts, could be re-chromed. PM me your email address.
