Old 10-13-2020, 06:04 PM   #21
Cobra Joe
Cobra Joe's Avatar
Default Re: Autolite Spark Users Only
Hard to tell by the picture, but does that look more like "oil fouling" than carbon fouling, it looks kind of wet?
I also run 216's
1957 Fairlane 500
1939 Ford Coupe
Cobra Joe is offline   Reply With Quote
Old 10-13-2020, 06:06 PM   #22
Phil Gillespie
Phil Gillespie's Avatar
Originally Posted by billybronco1 View Post
Only one real black one out of the 8
Possible that "black one" could be from a cylinder which may not be firing!
To check at all plugs/cylinders for firing. If ok then to next stage.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-13-2020, 06:06 PM   #23
drolston
drolston's Avatar
That is the same symptom I just tracked down on the "Missing at Full Throttle" thread. Turned out to be a broken connection in the spark plug cable to cylinder #2. With the engine at idle pull any other spark plug wire off and listen for the slight RPM drop. Put that wire back on and pull the wire from the offending cylinder; it will probably not affect the RPM, indicating that cylinder is not firing.
Check continuity of the spark plug wire from the distributor end to the plug end. If you are using solid copper plug wires it will read near zero Ohms. If you are using carbon core wires (bad idea) or spiral wound wires you will find resistance of up to 4,000 Ohms per foot.
And clean or replace the black plug.
drolston is online now   Reply With Quote
Old 10-13-2020, 06:16 PM   #24
billybronco1
I'm having trouble with a leaking head gasket or something in one cylinder you might have seen my other post. This plug could have come from that cylinder, don't know. Just ordered new plug and will watch every thing closely moving forward.
billybronco1 is offline   Reply With Quote
Old 10-15-2020, 01:03 PM   #25
billybronco1
Originally Posted by alanwoodieman View Post
Stromberg carb, so I would think too large jets, back up and take a picture of the engine head. take the air cleaner off and make sure it is not clogged up, It appears to be a dry type and the "cleaner" part of the air cleaner is a wrapped up bunch of fiber mesh just under the top cover ,remove wing nut and take it off and then remove this and see if the richness goes away
I took a closer look at the air cleaner yes has the steel wool and chicken wire does not seem super type or clogged but it also has a fiber type material on top under the cover, is that standard? I do plan to run it a bit with out the air cleaner to see what happens. Other good news previous owner found the original carb, (at lease original to him) says it ran the same as the replacement, but I plan to open it up and perhaps try different jets and power valves and do some experiments. I will start a new tread when I get into that and sure could use some advise.
Old 10-15-2020, 04:46 PM   #26
billybronco1
BTW how the heck do you replace the steel wool and rabbit wire in that air cleaner, it does not appear it comes apart.
Old 10-15-2020, 05:59 PM   #27
JSeery
JSeery's Avatar
It's not replaceable (at least not easily). You clean it in a solvent.
Old 10-16-2020, 12:30 PM   #28
billybronco1
I guess its hard to tell how the air flow is through the air cleaner without pulling all the stuff out. Do most guys run there stock cars with the original style air clean, seems it could be problematic.
Old 10-16-2020, 12:52 PM   #29
51 MERC-CT
51 MERC-CT's Avatar
Many have modified their original oil bath air cleaners to accept a dry modern filter.
Old 10-16-2020, 01:26 PM   #30
JSeery
JSeery's Avatar
The air blows down onto the surface of the oil then up through the filter material. It is not a direct path.
Old 10-16-2020, 04:29 PM   #31
flatford8
flatford8's Avatar
“Do most guys run there stock cars with the original style air clean, seems it could be problematic.”
Mine has been on my car for 70 years. It works just fine. The worst part of an oil bath air cleaner is forgetting it’s got oil in it and tipping it a little when you have it off making a mess.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-16-2020, 04:57 PM   #32
billybronco1
Mine is not an oil bath as far as I can tell
Old 10-16-2020, 05:37 PM   #33
JSeery
JSeery's Avatar
Turns out there are both dry and oil bath filters (so much for what I know!)
Old 10-16-2020, 06:38 PM   #34
billybronco1
Just steel wool or copper wool? Looks pretty black too, could be why it runs rich.
Old 10-16-2020, 06:43 PM   #35
JSeery
JSeery's Avatar
A past thread on this filter. https://www.fordbarn.com/forum/showthread.php?t=98754
https://www.earlyfordv8.org/forum/pr...=18&Topic=3401
Old 10-16-2020, 06:48 PM   #36
billybronco1
I think I'm going to opt for some kind of replacement and save this one for the next owner.
Old 10-16-2020, 10:41 PM   #37
TomO
To determine if the air cleaner is clogged, start the engine and let it idle. Remove the air cleaner with the engine still running, If the engine speed increases significantly, the cleaner is clogged. Clean and oil it.
TomO
TomO is offline   Reply With Quote
Old 10-18-2020, 09:33 AM   #38
Ol' Ron
Ol' Ron's Avatar
I don't understand why people don't buy an AF meter/ There not very expensive and can solve allot of problems in a fraction of a second!!!!!
Old 10-18-2020, 09:35 AM   #39
billybronco1
In what is an AF meter?
Old 10-18-2020, 09:58 AM   #40
tubman
tubman's Avatar
An "Air/Fuel" meter will tell you the ratio of fuel to air in the intake charge (generally around 14:1) by analyzing the engines exhaust. They essentially need two inputs; 12 volts to power them and a feed from the exhaust. They come with a special cable and a sensor the mounts into the exhaust stream. This can be done in one of two ways; either a bung can be welded into the exhaust pipe (ideally 36" from the exhaust port), or a "Sniffer Tube" that clamps temporarily into your tail pipe. . Obviously, the former is a better way of doing it, but that latter usually is satisfactory.
I have one mounted on my engine test stand. It works well, and cost about $120, including the gauge, cable, and sensor.
