Anyone drilled and tapped the later 8BA type blocks for a block drain. The 59L has one right where it should be, at front low point. The 8RT has none.
I assume you could probably drill out the 8BA at the same point for a drain. Or will the drain hole in the water pump get most of the water out of an 8RT. ? Thank you Fordbarners. |
I have drilled & tapped the 8BAs for drain cocks.
Really not needed as you can see, water pumps are low enough to drain OK. |
I have a 8CM in a 33 Ford would like to drain coolant without removing bottom hoses?
Thank you. That's what I thought about the water pump holes, but it is impossible to get the bottom hoses off in a tight '29 A roadster without removing the radiator. Good to hear drilling & tapping the block works.
The back of the engine is usually the low point, all the crap settles back there. I've seen where people drilled and tapped back there, but the metal isn't real thick there.
'52 F-1, EAB flathead |
As Ronnie stated, there is a good flat spot on both sides of the block at the front. I drilled and tapped both sides and installed drain cocks for the eng. in my 51 merc., and the eng. for my 29 roadster project. I did this so I did not have to remove hoses to drain cooling system, in case cooling system maintenance. ( heater hoses, heater control valve, t-stats, even head gaskets.) I did it mostly to be able to completely drain and change out the anti-freeze every couple of years. I will say that it is best done with the eng out of the vehicle. may not be possible in the vehicle
#8 | |
![]() Quote:
The bottom of the radiator might be good idea also, if there is spot like the '40 if I recall.
I have found this drain valve better than the old butterfly type. Available at boat stores or on ebay
Thanks, RUSSCC. Would you have a photo of that '40 spot on the block? Or would you try the radiator idea? I'm pretty new at this so you guys opinions really matter. Thanks again.
Thanks Paul2748. Would happen to have a photo of the spot where you installed it? I'm pretty new at this and you guys opinion really matters. Thanks again.
#13 |
As Ronnie pointed out, a drain on the radiator is still not going to totally drain the block.
#14 | |
![]() Quote:
#15 | |
![]() Quote:
Is kind of rounds out a bit like a semi-circle with a flat top. |
#16 |
Here is Jim's 29 roadster project block with the drain hole at the front flat spot.
#17 |
#18 |
That's one hell of a center bearing cap. Al
#19 |
On the flathead that I had, I did not use it. I am using
it on my Y Block cars, including the radiator
#20 |
