Old 06-06-2020, 04:49 PM   #1
rfitzpatrick
Default New Manufactured Zenith Carburators
Several vendors list them , tho out of stock. Priced about $500.00.
Has anyone bought one yet? If so -- what is your experience with it plz
Thanks
rfitzpatrick is offline   Reply With Quote
Old 06-06-2020, 05:44 PM   #2
Gary WA
Gary WA's Avatar
Default Re: New Manufactured Zenith Carburators
$$$$$ Nothing like the Real Thing!!
www.whidbeymodelaclub.com
Old 06-06-2020, 06:22 PM   #3
WHN
We have one our 29. Runs really great.
Tried a rebuilt original that I ended up replacing with the new Zenith.
They are expensive for a reason.
Enjoy.
Old 06-06-2020, 06:28 PM   #4
Mike Peters
Mike Peters's Avatar
Bought one when they first came out for around $250. Ran great the first season, but wouldn't start the car the next spring. So took it back to the vendor and he had it "rebuilt". Don't know exactly what the rebuilder did. Running great ever since. Vendor told me that all of them need to be worked over. This was years ago, so maybe the new ones are are better?
Mike Peters is offline   Reply With Quote
Old 06-07-2020, 07:01 AM   #5
marty in Ohio
marty in Ohio's Avatar
I bought a new one from Snyder's on the day I got my first social security check! I think I paid about $400 for it. I put it on my car and it wouldn't work. I called Snyder's and they told me that they stored them on their side and the float was probably stuck. Told me to wrap on the side of it with a screwdriver handle. Never a problem since. That was about 9 years ago!
Marty
marty in Ohio is offline   Reply With Quote
Old 06-07-2020, 08:03 AM   #6
McMimmcs
McMimmcs's Avatar
I bought one from Snyders and it was put on the day I received it with never a problem since. If you want quality it comes with a higher price tag. The same as Stipes shocks. You get what you pay for! If you want good clean oats they cost more than oats that have been through the horse one time !
Old 06-07-2020, 08:36 AM   #7
Dave Slater
Dave Slater's Avatar
I have three of them here, two won’t idle wort beans and the other lacks power at any speed. My original Zenith runs and idles fantastic. I have narrowed the problem to the top half on all three units.
Dave Slater is offline   Reply With Quote
Old 06-07-2020, 10:36 AM   #8
The Master Cylinder
The Master Cylinder's Avatar
Dave Slater, I have one that seems to run on the lean side. I have to run with the GAV opened farther than I would expect. I checked for vacuum leaks and found none. It runs fine with the GAV open ~1-1¼ open. Maybe try that.
One of these days I am going to rejet it to see if I can improve it.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 06-07-2020, 04:22 PM   #9
McMimmcs
McMimmcs's Avatar
After the first one failed, why did you buy 2 more ???
Old 06-08-2020, 01:14 PM   #10
barnstuf
These carburetors are made from repro parts, assembled and sold. They are not tested so that leaves room for the problems buyers experience.
barnstuf is offline   Reply With Quote
Old 06-08-2020, 01:18 PM   #11
Bob-A
Bob-A's Avatar
Smile Re: New Manufactured Zenith Carburators
I bought a used repop Zenith carb a few years ago for -$100-. The seller said it had problems with it. I've not had any problems with it and in fact it is on my car now.
Bob-A
Bob-A is offline   Reply With Quote
Old 06-08-2020, 01:23 PM   #12
Dave in MN
Dave in MN's Avatar
I purchased one of the AIR BALANCED ZENITH CARBS and ran it for the first 1000 miles of a road trip and it was getting about 4 miles to the gallon less than my original. I replaced it with the original and finished the trip. Put the new carb on the shelf when I returned from the trip about two years ago and kind of forgot about it. I will move it into my work area and start tuning....
Good Day!
I was running it with an air filter.
Dave in MN is offline   Reply With Quote
Old 06-08-2020, 02:41 PM   #13
30 Closed Cab PU
Good Day!
Interesting - keep us updated on what you find. Am assuming you are running an air filter?
Old 06-09-2020, 05:53 AM   #14
Dave Slater
I didn’t purchase any of them. They belong to other Model A owners
Old 06-09-2020, 06:28 AM   #15
jak
Brattons IS working on a batch of the new carbs. We have found a small stockpile of new castings and are currently working on assembly and testing them. If you are interested call and get on the list as these will be gone soon.
jak is offline   Reply With Quote
Old 06-09-2020, 03:52 PM   #16
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you’re running a modified engine IE bored different cam ect, then a re jet is a good thing.
Old 10-04-2020, 03:03 PM   #17
Apperloo
Apperloo's Avatar
I could use one of those ..........
I love a girl and "Ruby" is her name, ChaCha
Apperloo is offline   Reply With Quote
Old 10-04-2020, 03:28 PM   #18
The Master Cylinder
Chuck. Basically stock engine with Snyder 5.5 head.
Update: I found the problem. The hole for the throttle shaft was way too BIG, sucking in air. Made the engine run super lean and would not idle. I had to install an oversize throttle shaft to cure the problem. And this is a new carb?
Anyway, something to check for. I wouldn't buy another.
The Master Cylinder
Old 10-04-2020, 09:35 PM   #19
PalAl
PalAl's Avatar
Now that's funny......... I have never heard "buying a piece of $h**" described in such a nice way. One statement says it all. I love it, to bad this hobby is faced with this type of part
PalAl is offline   Reply With Quote
Old 10-05-2020, 09:27 AM   #20
30 Closed Cab PU
Another alternative is to purchase a rebuilt or have one rebuilt by Jim Bullock in Texas,. Flow tested jets, , tested, and does exceptionally nice work. The few people that have had issues report he makes things right quickly.
https://jmacarbs.com/
