Old 06-22-2019, 05:39 AM   #1
Patrick L.
Patrick L.'s Avatar
Default Ring gear, Old Fords are not
the only vehicle you can install the ring gear backwards in. A friend has just purchased a big ole sedan that has 4 speeds backwards and one forward. I'll be looking at it and will probably be getting my little fingers dirty soon.
Old 06-22-2019, 06:19 AM   #2
Joe K
Joe K's Avatar
Default Re: Ring gear, Old Fords are not
It must have a truck transmission?
Joe K
Shudda kept the horse.
Old 06-22-2019, 06:31 AM   #3
Jacksonlll
Jacksonlll's Avatar
Oh my, I did that when I was 16. Me and my buddy were doing something to his car and we got the thing in backwards and had three speeds in reverse on his 4 door A. I was so embarrassed, and wanted to fix it before any of our friends could see what a stupid thing we did. Not Ronnie, he wanted to drive it around the block in reverse, and he did. We fixed it REAL fast when he got back.
Old 06-22-2019, 07:17 AM   #4
chap52
chap52's Avatar
Let you without "oops" cast the first lug nut... Chap
Old 06-22-2019, 07:54 AM   #5
Joe K
Joe K's Avatar
I tell my wife "assembly is a learning process."
First assembly you end up with it upside down and backwards.
Second assembly, you have it only upside down.
Third time is you have it assembled correctly - but something is left over on the bench.
And you learn a whole lot in the repetition.
Joe K
Old 06-22-2019, 10:09 AM   #6
Patrick L.
Patrick L.'s Avatar
Originally Posted by joe k View Post
i tell my wife "assembly is a learning process."
first assembly you end up with it upside down and backwards.
Joe k
lol
Old 06-22-2019, 10:10 AM   #7
Patrick L.
Patrick L.'s Avatar
Its not a Ford guys. Its a somewhat local built high-end vehicle.
Old 06-22-2019, 10:52 AM   #8
30 Closed Cab PU
