Old 05-04-2016, 03:42 PM   #1
bunnyc
bunnyc's Avatar
Default Mystery Fuel/Carb Problem
'29 Tudor, '30 engine (stock), Zenith carb (new from Snyder's with 400+/- miles on it).
I needed a new muffler. Ordered one from Aries. Decided to also replace the manifold gasket.
Removed the carb, stored it upright. Removed the manifolds. Several days later assembled manifolds and mounted the carb.
Now I can't keep the engine running. If I pump the accelerator a couple times and pull out the choke with the GAV 3/4 turn open, it will run for 10 seconds, then stop. Like it's out of gas.
I don't understand what could have happened. I made no adjustments to the carb. It just sat on the shelf while waiting to be put back on.
Before, the car ran great and started within a couple revolutions of the engine.
I've taken the carb off and checked that the float is not stuck. Drained the bowl and see gas flowing through the sediment bowl to re-fill the carb.
Any suggestions are welcome.
bunnyc is offline   Reply With Quote
Old 05-04-2016, 03:55 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Mystery Fuel/Carb Problem
Since you had the manifolds off, I would look for an area around the intake manifold where air is being sucked in. Possibly a distorted gasket.
Tom Endy
Old 05-04-2016, 05:02 PM   #3
Gary WA
Gary WA's Avatar
Did u turn the gas valve on? Just a thought! Goes up and down, not in line with valve!
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 05-04-2016, 05:14 PM   #4
mot
Registered User
mot's Avatar
did you push the gas line too far into the carburetor?
mot is offline   Reply With Quote
Old 05-04-2016, 05:15 PM   #5
1931 flamingo
1931 flamingo's Avatar
Manifold(s) leak?? Are you sure the muffler is (was) clear before installation??
Fuel flow?? Fuel bowl not filling?? Please keep us in the loop.
Paul in CT
Old 05-04-2016, 05:36 PM   #6
bunnyc
bunnyc's Avatar
Yes, gas valve is on (up and down)
Fuel line was disconnected at the sediment bowl, only. Didn't remove fuel line from carb.
Paul in CT
New muffler has not arrived. Starting w/o any muffler. Fuel bowl is filling.
Tom Endy
Carefully checked gasket for alignment before installing manifolds. Trimmed excess gasket from valve cover gasket to make sure manifold gasket was flush with head. The manifold gasket is the two piece type that has holes that fit over the studs. Manifold nuts are not torqued - tight with 3/8 drive ratchet. Possibly not tight enough?
Old 05-04-2016, 05:41 PM   #7
700rpm
700rpm's Avatar
Did you replace the carb gasket where it meets the intake manifold? Are those bolts snug?
Ray Horton, Portland, OR
Old 05-04-2016, 05:47 PM   #8
William Kelchner
William Kelchner's Avatar
I'm with MOT, having done this very same thing with identical results.. Cheers
William Kelchner is offline   Reply With Quote
Old 05-04-2016, 06:00 PM   #9
Mitch//pa
Could be pushed to far in the sediment bowl... Same set up as carb side
Old 05-04-2016, 06:06 PM   #10
George Miller
George Miller's Avatar
Did you use gland rings. Sounds like a vacuum leak to me.
George Miller is offline   Reply With Quote
Old 05-04-2016, 06:09 PM   #11
bunnyc
bunnyc's Avatar
UPDATE: I decided to break out the torque wrench for the manifold nuts. Tightening to 25 ft/lb (about a half turn on the nut) there was improvement. The engine ran 30 sec or so before shutting down. I was using my normal starting procedure, not pumping the gas pedal.
Tightening further to 30 ft/lb got it running and starting normally.
Thank you all for your suggestions. It was very frustrating for me. Learned something from this. You guys are great!
Old 05-04-2016, 06:14 PM   #12
Jon
Jon's Avatar
Don't pump the accelerator, you will flood it for sure!
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 05-04-2016, 06:38 PM   #13
wmws
Don't worry about pumping the accelerator pedal. That won't flood the engine because there is no accelerator pump in the carburetor.
wmws is offline   Reply With Quote
Old 05-04-2016, 07:28 PM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
We tole you, those are BIG bolts, tighten them accordingly! I do them 55FT LBS, in stages.
Bill W. & the Dog
"THE ASSISTANT GURU OF STUFF"
Old 05-04-2016, 07:32 PM   #15
pgerhardt
pgerhardt's Avatar
That's right! But the model A is VERY easy to flood by over choking.
pgerhardt is offline   Reply With Quote
Old 05-05-2016, 05:21 PM   #16
Jon
Jon's Avatar
yup, just wondering if any one else saw that.
Old 05-05-2016, 07:43 PM   #17
redmodelt
redmodelt's Avatar
My dad use to say; never put a new muffler on an old car, it will go bluuey for sure!
Old 05-05-2016, 09:22 PM   #18
tbirdtbird
pumping the gas pedal on an A with an updraft carb will have no effect whatever.
There is no accel pump and even if there were the excess gas would just drain out the carb throat onto the ground.
As stated flooding comes from over-choking
'31 180A
tbirdtbird is offline   Reply With Quote
