Old 11-27-2020, 11:14 PM   #81
fredski53
fredski53's Avatar
Default Re: 16" Wheels
Mike85212, wish I lived closer to you! I think those 16" look bitchin on a Vicky!
fredski53 is offline   Reply With Quote
Old 11-28-2020, 12:11 AM   #82
Mike85212
Mike85212's Avatar
Fredski53....you should take some time off and come to the desert for a while in the wintertime and get out of the cold snowy weather!
Mike85212 is offline   Reply With Quote
Old 12-01-2020, 10:26 PM   #83
fredski53
fredski53's Avatar
Mike, if I was to show this post to the wife, I know she would jump at the chance to go somewhere warm! Question, when you had the 16" wheels on your Victoria, did the tires rub the front brake rods? How wide are the tires?
Old 12-02-2020, 01:42 AM   #84
Chris Haynes
Chris Haynes's Avatar
Originally Posted by Vic in E-TN View Post
Chris Haynes had his 16 inch wheels widened 1.5 inches. Does anyone know how this is done and can they recommend anyone to do it? I am in Tennessee.
Vic
I had mine done at Pico Wheel. 818-421-6102
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-02-2020, 10:08 AM   #85
AL in NY
AL in NY's Avatar
Widening the wheels seems like a lot of expense for not much gain. I have stock 5 inch wide 35 Ford wheels on which I mounted 225/75R16 tires. The tires don't like at all oversized for the rims and the tread width is 7 inches. Unless you're looking to install 10-11 inch wide tires, the stock rims work fine.
AL in NY
AL in NY is offline   Reply With Quote
Old 12-02-2020, 01:28 PM   #86
Chris Haynes
Mounting a wide tire on a narrow rim causes the tire to crown. This crowning will cause the center of the tire to wear faster than the rest. Check the tire manufacturers listing to find out the suggested rim width for the tire you want to use.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-02-2020, 09:02 PM   #87
Mike85212
Mike85212's Avatar
Hi Fred, The tires are 6.5 X 16.
No, they did not rub anything. Obviously we all know that there are a lot of cars out there running 16” wheels I think it really comes down to personal preference. To say that there is a right or a wrong is not correct.
Mike
Old 12-02-2020, 10:25 PM   #88
DBSHELTON
Got the 16" wheels on and the 155/90-16 spares too.
DBSHELTON is offline   Reply With Quote
Old 12-03-2020, 06:27 AM   #89
shew01
shew01's Avatar
I like that.
Old 12-03-2020, 06:50 AM   #90
jbwthree
jbwthree's Avatar
Looks gorgeous all around, nice vehicle dbshelton !
jbwthree is offline   Reply With Quote
Old 12-03-2020, 10:00 AM   #91
Licensed to kill
Licensed to kill's Avatar
I don't know what it costs to have a wheel widened but you can have new ones made in a variety of widths and diameters. They are not cheap but they are brand new and sealed for use with tubeless tires. I've had two sets made by the "wheel smith" out of california. I have a dozen real nice original '35's, two of which will be used for the spares on my DD. I know that stock '35's are dirt cheap compared to brand new ones but if you want wider than stock, going new and running tubeless is an option.
Licensed to kill is offline   Reply With Quote
Old 12-03-2020, 11:17 AM   #92
Jack Shaft
I run 35 ford wires tubeless with no issues, I do use metal valve stems. At fifty bucks a tire crowning is a non issue,a wide footprint distributes the low weight just fine.If I get five years out of the tires thats 40 bucks a year cost..how cheap does it have to be?
Old 09-27-2022, 11:26 AM   #93
Madster
Madster is offline   Reply With Quote
Old 09-27-2022, 11:38 AM   #94
Madster
Originally Posted by Randy in ca View Post
____
Is that rear wheel widened?
