Old 05-04-2012, 11:53 AM   #1
Dana Barlow
Question hub screw on grease caps,chrome?
I'd really like to have shiny front screw on grease cover caps; chrome or stainless or even brass grease caps,as I don't run hub caps at all on speedster,dose anyoneknow if someone sells them chromed or something.
I tryed shining the steel,but dose not hold shin very long even with clear coat over them.
Thanks
Dana
As extra ? what years did hubs come with the screw on type vs push on?
Dana Barlow is offline   Reply With Quote
Old 05-04-2012, 12:22 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: hub screw on grease caps,chrome?
Get 'em chromed if that's what floats your boat.
Old 05-04-2012, 01:07 PM   #3
19Fordy
19Fordy's Avatar
My 40 Ford had "screw ons." If you have a lathe you could actually make your own.
Old 05-04-2012, 01:23 PM   #4
Rustyspokes
Rustyspokes's Avatar
My 34 ..Has the screw on caps on the front , none on the rear..
Rustyspokes is offline   Reply With Quote
Old 05-04-2012, 02:04 PM   #5
Lawson Cox
Lawson Cox's Avatar
No Ford has dust caps on rear hubs, only the front.
Old 05-04-2012, 06:41 PM   #6
Dana Barlow
Thumbs up Re: hub screw on grease caps,chrome?
I looked around,and can find the push in type that are chrome,so was thinking there maybe someplace that makes them that way?
I could make push in on my leath,but I'm not good enough to tread them.
Old 05-05-2012, 08:40 AM   #7
19Fordy
19Fordy's Avatar
Dana, Give it a try. You will be surprised how easy it is. What kind of lathe do you have? I don't have my threaded dust caps anymore. Do you know what size threads the OEM caps have? JIM
Old 05-05-2012, 09:26 AM   #8
flatheadA
The only problem your going to have with chrome on your caps is ,it also chromes the threads.If you notice the threads are fairly tight,when you screw them on it's a tight fit.Now when you chrome them it adds more thickness to the threads and makes it harder to thread on to the hub.I'd be worried if you got them on,you may not get them off.
Just my 2 cents,I've run into this problem in my line of work.
flatheadA is offline   Reply With Quote
Old 05-05-2012, 09:37 AM   #9
Fordors
The thread is 2" - 24, and the chrome shop will have tape that can be used to mask the threads.
Fordors is offline   Reply With Quote
Old 05-05-2012, 02:20 PM   #10
19Fordy
19Fordy's Avatar
Thanks for that thread size and tape info.
Old 05-05-2012, 04:46 PM   #11
Fordors
You're welcome, I'm glad I could be of assistance.
Old 05-06-2012, 12:04 AM   #12
Dana Barlow
I'm always amazed by the good help on here,thanks.
