Old 02-19-2012, 03:49 PM   #1
barnfind08
Default 1935-37 scoop oil breather
Does anyone know how to remove the screen on this breather? Can it be done? Has it been done by anyone? Or are we left to just clean it blow it out clean it blow it out. If I remove it is there someone who sells a replacement? The ideal thing I want to do is remove the screen, powdercoat the can(breather) and replace the screen. Thanks everyone.
barnfind08 is offline   Reply With Quote
Old 02-19-2012, 04:44 PM   #2
flatheadfan
flatheadfan's Avatar
Default Re: 1935-37 scoop oil breather
The only way I have been able to do it is by opening up the scoop. It doesn't take much, the screen is only held it place by a couple of small bosses. As for a replacement screen I just use common window screen and spool it up. Once spooled I just use a couple of pop rivets or wire to keep it spooled. Insert the screen and compress the scoop back into position. I am sure others have done it and they may have a simpler way that works for them.
Hope this helps.
Tom
flatheadfan is offline   Reply With Quote
Old 02-19-2012, 05:09 PM   #3
Charlie ny
BF,
What FHF said....to ease the installation place a couple thicknesses of wax
paper all around the screen. This will reduce marring of your new finish & keep you
from having to use those special words. It requires some patience to get all the
wax paper removed but it's worth it.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 02-19-2012, 07:54 PM   #4
ford38v8
ford38v8's Avatar
Charlie, I haven't done it, but if it's that difficult to prevent scratching the scoop, I'd think it wise to practice the method before painting the scoop.
Also, has anyone come across any documentation of a scoop on a '37?
Alan
ford38v8 is online now   Reply With Quote
Old 02-19-2012, 11:35 PM   #5
barnfind08
Flatheadfan I will give it a try tomorrow on a couple of breathers if it works I owe you.
