04-12-2021, 06:40 AM | #1 |
1941 pickup with ford 226 motor
Is there a source for a lower molded radiator hose for a 1941 ford pickup with a 6 cylinder 226 engine?
I would guess cars and pickups with a 6 cylinder up to 1947 pu and 1948 car would be the same. |
04-12-2021, 08:28 AM | #2 |
Re: 1941 pickup with ford 226 motor
For the hose try some of the V-8 vendors listed in the V-8 Times.
04-13-2021, 06:27 PM | #3 |
I doubt the hose is the same. The radiator location for the 41 pickup with 6 was different from what came later. It may be similar to 41 car with 6, but I doubt the same.
Can you use molded rubber elbows with a straight piece of pipe in between? |
04-14-2021, 09:47 AM | #4 |
Make a pattern using old pieces of hose and some pieces of metal tubing. Take the pattern to your local auto parts store and they will usually let you look at the hose selection and you can try to match the pattern. You may have to buy a hose that is longer and you can cut it to fit. My Napa Auto Parts store is very good at letting me search the hose selection. Save the hose # for the future.
04-14-2021, 09:51 AM | #5 |
