Old 04-09-2021, 09:25 AM   #1
alexiskai
alexiskai's Avatar
Default Parts list for rebuilding headlights
My late '29 two-bulb headlights were messed up when I got the car - wrong wires, wrong reflector, quartz fixture, rusted conduit, etc. I need to get it back to stock, but I can't find an assembly diagram of which parts I need to completely replace the innards.
Does this list look right (using Bert's part numbers)?
13081-A set of two focus springs and screws
14584-B set of two headlight plugs
13120 (x2) socket holder
13075-B (x2) headlight wiring, '29 two bulb
14578-C SS conduit set
13026-D set of aluminum plated reflectors
The lens, rim, and shell are correct. I'm also getting a new harness from Sac Ford.
Old 04-09-2021, 09:34 AM   #2
Badpuppy
Default Re: Parts list for rebuilding headlights
Looks complete to me, except for the bulbs.
Badpuppy is offline   Reply With Quote
Old 04-09-2021, 09:42 AM   #3
alexiskai
alexiskai's Avatar
Yeah, the bulbs are accounted for
Old 04-09-2021, 10:50 AM   #4
ericr
ericr's Avatar
wasn't there a gentleman years ago that sold restored headlights?
ericr is offline   Reply With Quote
Old 04-09-2021, 11:09 AM   #5
JayJay
Delete post
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 04-09-2021, 12:33 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I think you are probably thinking of Don Hesse that sold restored lights on eBay under the name Cobalta. Most of what he was doing is restoring stainless lamps though. Finding head lamp cases in good enough shape to replate is difficult. Finding someone (-besides Craig) to affordably replate them in Nickel is even more difficult.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-09-2021, 12:38 PM   #7
BRENT in 10-uh-C
Colin, you make no mention of glass lens, the cork seal, the lens retainer clips nor the rim retainer. Are those OK on yours??
BRENT in 10-uh-C
Old 04-09-2021, 01:16 PM   #8
alexiskai
alexiskai's Avatar
The lens is good, it's a new correct lens. The clips are good and the retainer is good.
I should get a new seal, is there a functional difference for cork vs neoprene?
Old 04-09-2021, 01:29 PM   #9
midgetracer
midgetracer's Avatar
For me, cork seems to stay in place better than neoprene...Besides that it is original.
midgetracer is offline   Reply With Quote
Old 04-09-2021, 01:40 PM   #10
alexiskai
alexiskai's Avatar
Thanks, I was able to get most of it from SVF, and the rest from Bratton's. SVF did not have stock of the new Bratton's reflectors, the plugs, or the SS conduit.
Old 04-09-2021, 04:28 PM   #11
john charlton
john charlton's Avatar
I would stay away from Fords original connection setup between the lamp wires and the harness . Some offshore parts I have seen would allow a short at the junction . I leave the "bullets" on the wire ends and connect with the rubber covered steel sleeves . The three sleeves fit neatly in the conduit end /headlamp . There is a neat tool called a Rippault here in the UK that is a plier with slots you should have one in USA like that nice click when they engage .
John in damp cold Suffolk County England .
john charlton is offline   Reply With Quote
Thread Tools
Display Modes
