03-12-2021, 12:53 PM | #1 |
Model b waterpump
I currently have 32 model b engine in my 30 A, The housing on the B water pump is cracked, I have a Model A head,and after doing some research, I believe I can buy an A pump and change out the B pump by installing the A head, BUT, I have been told by some, there are more water ports on the B head. Can someone with more experience than me, shed some light on my issue
03-12-2021, 01:16 PM | #2 |
Re: Model b waterpump
Just for clarification, the situation is:
Why not just buy a B pump? |
03-12-2021, 01:40 PM | #3 |
#1 Hard to find #2 cost, obviously you have more money than me
03-12-2021, 02:03 PM | #4 |
03-12-2021, 03:10 PM | #5 |
Michael,
Have you checked with the suppliers to see if any of them have an adapter? Perhaps someone on the HAMB may know where to get one. David Serrano |
03-12-2021, 04:14 PM | #6 | |
03-12-2021, 04:39 PM | #7 | |
Secrets of Speed https://www.secretsofspeed.com/water-connections has one also for $58. David Serrano |
03-12-2021, 04:42 PM | #8 |
These are not the right adapters, these adapt the V8 pump to the model A head. SoS does sell an $85 adapter farther down the page that adapts the V8 pump to the B head. The V8 pumps are readily available. Only problem is you have to customize the pump to mount the B fan on the end of it.
03-12-2021, 07:22 PM | #9 |
My '31 has a late model ('39 casting) B engine with an A head and an A water pump. It works flawlessly and has over 2000 miles on it.
I have compared the A head gasket and B gasket and either will work fine IMO. Some say the copper type works best but opinions vary - and should be based on the head (A or B) design. Tom |
03-12-2021, 07:26 PM | #10 | |
Charlie Stephens Last edited by Charlie Stephens; 03-12-2021 at 07:35 PM. |
03-12-2021, 07:45 PM | #11 |
That is interesting in that there are two different lengths with these Model B Water Pumps. The long one is 1932 while the shorter one is 1933-1934. Thanks for this helpful tip. Last edited by mercman from oz; 03-13-2021 at 05:55 AM. Reason: Description change |
03-12-2021, 09:05 PM | #12 | |
That shouldn't be the case; if you use the Model A head gasket with the model a head (which you should), those holes don't exist either in the gasket or the head. The gasket should seal off the holes - but to be sure, one could seal them first fairly easily. Also notice that the B gasket width between cylinders (at valve side) is wider than the A gasket, so that would likely lead to premature failure if used with the A head. Both these gaskets are quality; the B is Felpro, the A is a Best product. Here's a pic of the gaskets side-by-side: modelAgaskets.jpg Last edited by kawagumby; 03-12-2021 at 09:18 PM. |
03-13-2021, 12:09 AM | #13 | |
Charlie Stephens Last edited by Charlie Stephens; 03-13-2021 at 01:59 AM. |
03-13-2021, 12:16 AM | #14 |
The '33-'34 pump was shorter because the radiator sloped back.
Charlie Stephens Last edited by Charlie Stephens; 03-13-2021 at 12:03 PM. |
03-13-2021, 12:37 AM | #15 |
Easy to spot at a swap meet due to the space between the grease fittings.
Charlie Stephens Last edited by Charlie Stephens; 03-13-2021 at 12:01 PM. |
03-13-2021, 02:34 AM | #16 |
Trevor. The long one is 32 and the short one is 33/34
03-13-2021, 05:57 AM | #17 |
Thanks for the correction. I have now corrected the details in my original Post 11.
03-13-2021, 10:35 AM | #18 |
Go ahead and run the Model A head on the B engine. You can use either the A head gasket or the B head gasket. The A head stock has a 4.2:1 Compression Ratio and the B has a 4.6:1 Compression Ratio. The difference is too small to matter.
Bob Bidonde |
03-13-2021, 10:58 AM | #19 |
Vince has some good information on why you need to plug the steam
holes when mixing A and B heads and blocks. http://www.fordgarage.com/pages/ABcy...asketguide.htm |
03-13-2021, 11:05 AM | #20 | |
