Old 06-02-2020, 10:05 AM   #1
jimvette59
jimvette59's Avatar
Default What is this clutch arm
Hi any body know what car this came out of? I got it in a Lincoln case but I can't identify it.
jimvette59 is offline   Reply With Quote
Old 06-02-2020, 10:15 AM   #2
lotsagas4u
Default Re: What is this clutch arm
1935 something
lotsagas4u is offline   Reply With Quote
Old 06-02-2020, 10:50 AM   #3
barnfind08
It’s a Lincoln lever
barnfind08 is offline   Reply With Quote
Old 06-02-2020, 11:22 AM   #4
Tinker
Tinker's Avatar
Here is a chart for 32-35 Ford clutch arms (not Lincoln). For anyone searching for clutch arms.
Old 06-02-2020, 11:42 AM   #5
jimvette59
jimvette59's Avatar
Thank you. Lincoln to bad it's offset I need one that length but straight up. It's 4 15/16" C/C .
Old 06-02-2020, 11:53 AM   #6
flatheadmurre
flatheadmurre's Avatar
They are forged steel so heat bend and weld if you need a special shape...
Old 06-02-2020, 12:52 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
That "H" denotes Lincoln. Show us a pic of the case to maybe get the year in the ballpark. Does the case have a serial number stamped into it? DD
Click Links Below __
T5 W/TORQUE TUBE
