03-15-2016, 07:08 PM | #1 |
Thermostat Use?
I've done a couple searches and read several threads.
I did read one thread that indicated that Model A's did not originally come with thermostats in the cooling system. Is there any reason at all to NOT use a thermostat in the cooling system? It seems to me that having a 160° thermostat is a good choice.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
03-15-2016, 07:58 PM | #2 | |
Re: Thermostat Use?
03-15-2016, 08:52 PM | #3 | |
Re: Thermostat Use?
03-15-2016, 10:24 PM | #4 |
Re: Thermostat Use?
A theromostat solved a few issues I was having with excessive flow and over heating. I see no reason not to try one.
Blackwall Panthers Nor Cal chapter |
03-15-2016, 11:02 PM | #5 |
Re: Thermostat Use?
I believe a thermostat can only be a good thing. With a higher engine temperature you will get more complete combustion. If your engine is not running hot enough, the BAD stuff that gets by your rings (unburned gas, water, etc.) will condense in your crankcase, dilute your oil and circulate thru your engine. If it is kept in a vapor form it will go out the breather. I have a 180° thermostat.
This is a also a good argument for a Fumaze or Flex Tube breather to route under car by the way because they draw out the blow by. . Last edited by Y-Blockhead; 03-16-2016 at 11:56 PM. Reason: Correct Grammar... |
03-15-2016, 11:13 PM | #6 |
Re: Thermostat Use?
03-15-2016, 11:34 PM | #7 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Re: Thermostat Use?
Have an original 1920s era BOYCE motometer on a 31' Model A Ford that appears to accurately monitor the coolant temperature. The vehicle runs steady and normal. Operating that car in it's original form without thermostat seems to work okay. Back in the old days, we used to use straight distilled water in our Model A Ford radiators. In retrospect . . . that was mostly stupid. Nowadays, I run PEAK brand antifreeze-coolant and all seems well.
03-16-2016, 06:53 AM | #8 |
Re: Thermostat Use?
I like to drive my Model A on nice days in New England that can be anywhere from 40* to 90*. My 160* T-stat and Berg HD radiator keeps the engine well within the "operating range" in all conditions so far. I'm very happy with this setup,.............Pete
03-16-2016, 07:22 AM | #9 |
Re: Thermostat Use?
Like was said the operating temperature of the engine needs to be in the 160 range for a proper burn of the current fuel on the market. I was using a moto-meter for years to watch the temp and was shocked to find that my phaeton was only getting to 140 on a really warm day. I had installed a modern high quality temp gauge to find this out. Have since installed the 160 degree thermostat on each of the cars we tour in.
03-16-2016, 09:31 AM | #10 |
Re: Thermostat Use?
My engine builder recommends (and furnished) a 180° Thermostat.
03-16-2016, 10:00 AM | #11 |
Re: Thermostat Use?
I run a 180° thermostat on mine. Keeps the water nice and warm for my under seat heater.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
03-16-2016, 12:09 PM | #12 |
Re: Thermostat Use?
I also use a 180* thermostat.
03-16-2016, 06:56 PM | #13 |
Re: Thermostat Use?
I have not had an overheating problem since I installed the 160 Thermostat. It regulates the temperature very well, and most of all, it gives you complete peace of mind That's important.
03-16-2016, 07:30 PM | #14 |
Re: Thermostat Use?
Thanks to everyone..
The 160° thermostat is installed.... Tomorrow is supposed to be sunny...time for a test drive!
03-16-2016, 07:34 PM | #15 |
Re: Thermostat Use?
An engine is a water HEATER, a radiator is a water COOLER, a THERMOSTAT is needed to co-ordinate the water flow!--SIMPLE!
Bill W.
03-16-2016, 10:50 PM | #16 |
Re: Thermostat Use?
Hadn't factored in the use of modern day corn on the cob infused petrol. When I last was running Model A Fords, we had plenty of nice cheap wholesome LEADED gasoline available.
Okay then, where does the thermostat go within a standard Model A Ford 4-banger engine? Also too, will the increased temperature cause the antique Boyce Motometer to overheat and explode? As the wounded bank robber said to Dirty Harry, "I gutts ta know . . .!" |
03-16-2016, 11:03 PM | #17 |
Re: Thermostat Use?
I got one of these thermostat housings from Vintage Precision.
03-17-2016, 12:00 AM | #18 |
Re: Thermostat Use?
I slip the stat into the top hose as close to the engine as possible, and I slip a plastic barbed fitting into the hose to hold it in place, so it doesn't get pushed to the top of the hose by water pump pressure. I buy a barbed coupler at Menards for 2" ID hose. I can then cut about 1" off each end with the barbs and thus have 2 fittings for 2 of my cars. At first I used a piece of lower radiator pushed inside the top hose, and this works well also, but I don't always have an old lower hose around to cut up.
03-17-2016, 01:20 AM | #19 |
Re: Thermostat Use?
Been using one in My Model T and one in my Model A, 180 degree for 15yrs. works great.
03-17-2016, 08:26 AM | #20 |
Re: Thermostat Use?
While I have a thermostat, I have not installed it yet.
Currently, I use cardboard placed between the radiator and the stone guard. I raise it up or down to adjust for 160 degrees. Not very pretty, but it works. Marc |
