Old 12-01-2015, 04:49 PM   #1
mfagan
mfagan's Avatar
Default 1936 vs 1939 Transmission
In the continuing saga of installing an 8ba into a 1936 coupe
I would appreciate comments regarding upgrading the transmission
to a 39 model.
Are there significant benefits to the 39 over the 36?
Thanks for all the help.
mfagan is offline   Reply With Quote
Old 12-01-2015, 06:35 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 1936 vs 1939 Transmission
Synchromesh is greatly improved. The later gears can be installed in the early cases, but the '39 forks must be used. Do not try to modify the earlier forks.
You can use your '36 motor mounts with the later cases, but the '37 & later mounts offer more stability. For this conversion, you'll need to weld the later frame mounts, and modify the later tranny mount to accept the hand brake.
Alan
Old 12-01-2015, 07:35 PM   #3
Brendan
Brendan's Avatar
[QUOTE=ford38v8;1198902]Synchromesh is greatly improved. The later gears can be installed in the early cases, but the '39 forks must be used. Do not try to modify the earlier forks.
You can use your '36 motor mounts with the later cases, but the '37 & later mounts offer more stability. For this conversion, you'll need to weld the later frame mounts, and modify the later tranny mount to accept the hand brake.[/Quote
all I did was use the 36 trans baring retainer and 36 rear mount. everything bolted right up. the only thing I had to change was the arm for the clutch
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 12-02-2015, 12:21 PM   #4
Fred A
Fred A's Avatar
[QUOTE=Brendan;1198928]
Originally Posted by ford38v8 View Post
Synchromesh is greatly improved. The later gears can be installed in the early cases, but the '39 forks must be used. Do not try to modify the earlier forks".
Modifying forks was pretty common and reasonably useful years ago, but the second-hi fork used a different coaxial offset for the later synchro which was fixed by drilling a new rivet hole in the right place on the shift rail. Grinding the fork to the 3" spread completed the fit. Such mod is beyond todays needs with the access to the superior late 81, double detent tops with the right fork being available.
"You can use your '36 motor mounts with the later cases, but the '37 & later mounts offer more stability. For this conversion, you'll need to weld the later frame mounts, and modify the later tranny mount to accept the hand brake.[/Quote'
Seems like a lot of work for little to no improvement over the '36 rear retainer and mount. Fred A
"all I did was use the 36 trans baring retainer and 36 rear mount. everything bolted right up. the only thing I had to change was the arm for the clutch
That's the systematic simplicity that made these old Fords great.!
Good Luck: Fred A
Fred A is offline   Reply With Quote
Thread Tools
Display Modes
