Old 05-23-2015, 07:59 PM   #41
1955cj5
1955cj5's Avatar
Default Re: A vs AA Transmission
And one more thing.....
Anyone know what the oil capacity is for the AA transmission?
I've searched and searched and haven't found anything...
I've read that the A is one pint..
I've put two quarts in the AA and it's still not quite full, and now I'm out of oil but it's nearly full as I can see it through the filler...
It sure shifts better with te 600w and it's quieter too...
Randy
1955cj5 is offline   Reply With Quote
Old 05-24-2015, 09:20 PM   #42
1955cj5
1955cj5's Avatar
Randy
I found the answer....I had to sign up over at thee aa-ford forum so I could search..
The AA transmission holds 6 pints...3 quarts.....considerably more than the A transmission.....
Old 06-28-2015, 05:26 PM   #43
1955cj5
1955cj5's Avatar
I have solved the shifting problem. The pressure plate was out of adjustment and as a result the clutch linkage was way out of whack...
Shifts fine now...
http://www.fordbarn.com/forum/showthread.php?t=172037
Old 08-01-2015, 07:18 PM   #44
1955cj5
1955cj5's Avatar
I thought I'd post a couple of pictures of the AA and A bell housings side by side....about 1 7/8" height difference...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
Old 10-23-2015, 10:54 PM   #45
1955cj5
1955cj5's Avatar
I learned a couple more things about the AA vs the A transmission...at least on my installation..
Mine has a 32 or 33 BB rear transmission bearing retainer...BB-5089-A..i found one on ebay...
And the bolt spacing on the u-joint clamshell is 2 7/8" vs the 2 3/4" spacing on the A clamshell with evenly spaced holes...
Old 10-23-2015, 11:00 PM   #46
1955cj5
1955cj5's Avatar
Don't know..it's in there..I didn't put it there....the upper ears have been broken off...
Remember I have a 4-speed, which must be AA because the pedals still mount on the transmission case...
I looked at a fellow's 30 ccpu the other day, he has a 4 speed...the rear bearing retainer is very different...
But this is a picture of mine...
Old 02-28-2016, 02:54 PM   #47
1955cj5
1955cj5's Avatar
I recently bought a copy of the Service Bulletins. While paging through I noticed this subtle difference between the 4-speed and 3-speed on page 509...
And sure enough my old AA clutch shaft was offset, but the replacement was an A shaft and so though most of my shifting problems with the 4-speed had been resolved with new bearings, clutch disc and pressure plate, this just created a new problem....
AA 4-speed shaft on the right...
4-speed is gone now and the 3-speed works great.
Old 02-29-2016, 01:26 AM   #48
Mike V. Florida
Mike V. Florida's Avatar
He might be in the market for your AA tranny if you are thinking about selling.
http://www.fordbarn.com/forum/showthread.php?t=190358
