Go Back   The Ford Barn > The Swap Meet > Wanted > Late V8
Old 05-19-2013, 04:19 PM   #1
Dana Barlow
Question Found,thanks Ford Barn
City: Miami
State: Fla.
I'm missing the part to screw my speedO cable too,that fills hole in tranny and has the little gear in it held with one bolt. Whats it really called?
Not sure year,but is three speed tranny behind my Y-block 292. At this point I don't care about gear teeth count,can do something later about that after I get new tires on as well
Dana Barlow is offline   Reply With Quote
Old 05-19-2013, 05:55 PM   #2
clcrown
Default Re: 57or? up,SpeedO tranny plug w/grear 3s stick
Do you mean the end of the speedometer housing that has a o ring seal and the speedometer gear plugs into the cable in it.
clcrown is offline   Reply With Quote
Old 05-19-2013, 10:21 PM   #3
cb
I have a speedo cable I just took out of a 58 ford with a 3spd. stick it has the gear and the little bracket that holds it in the tranny, you will need to come up with the bolt for the bracket.
cb is offline   Reply With Quote
Old 05-20-2013, 10:43 AM   #4
Dana Barlow
Wink Re: 57or? up,SpeedO tranny plug w/grear 3s stick
Yes clcrown ,thats it.
Sounds good CB,I do have the cable and housing that runs from speedo in dash to tranny,but not what in hooks to in the tranny. So its what fills the hole in tranny and holds the plastic gear,I don't have the little gear ether,so need both
Old 05-20-2013, 11:30 AM   #5
Tinker
Tinker's Avatar
If you can't find one here from someone, check with lmc truck.
Old 05-21-2013, 08:00 AM   #6
Dana Barlow
Default Re: Found,thanks Ford Barn
Thanks CB,thats a big help,I'll send $ and Pm
