03-21-2019, 09:29 AM | #1 |
8ba in 36 5 window
Has anyone any experience in handling steady rod installation on an 8ba in a 36 5 window with a 39 transmission.
Any ideas or help would be appreciated.
Marvin Fagan 214-697-8430 |
03-21-2019, 01:39 PM | #2 |
Re: 8ba in 36 5 window
Look here:
https://www.fordbarn.com/forum/showthread.php?t=163974 and https://www.jalopyjournal.com/forum/...-coupe.243922/ one of the biggest problems is making the 8BA fan set up work. Modification is needed. Here is a thread that tells how another Fordbarn member did it. Read last thread and links. https://www.fordbarn.com/forum/showt...8ba+1936+coupe Last edited by 19Fordy; 03-21-2019 at 05:22 PM. |
03-21-2019, 10:38 PM | #3 |
Had a 50 Merc engine in a 36 convertible back in the 50's. Don't remember any problems.
03-21-2019, 11:29 PM | #4 |
Marvin, you may have to turn/grind forged stop off, then run a thread die on for 1" or so. Spin first nut down to have adjustable stop. Trap bellhousing with second nut. Lock washers.
03-21-2019, 11:34 PM | #5 |
Look at 19forty links. best to my knowledge the fan becomes an issue, thought about doing it once. Angled radiator on a 36.
Truck engine parts will link to a earlier transmission. Waterpumps needed too and the oil pan. Trucks still had a straight axle. Had a cracked truck block with all the goodies. Pasted it to a club member. Some more to read https://www.fordbarn.com/forum/showthread.php?p=991078 https://www.jalopyjournal.com/forum/...-coupe.243922/ Some more... on 8ba/rt to 39 trans. https://fordbarn.com/forum/showthread.php?t=161099 Best of luck, hope to see the progress! Last edited by Tinker; 03-22-2019 at 01:05 AM. |
03-22-2019, 09:34 AM | #6 | |
Please clarify. |
03-22-2019, 10:32 AM | #7 |
Seems fairly clear to me. Not sure I totally agree with the approach, but I understand what is suggested. 34p-kup is recommending grinding the original flange off (most likely forged, not case) so the stay rods are a consistent diameter. Then using a die to thread the section where the flange was and using a nut on either side of the hole in the bellhousing/block so that the effective length of the stay rods are adjustable. The issue I see is that the 8ba does not have the holes required for the stay rods, correct. So, a plate needs to be added to accommodate the rods.
03-22-2019, 11:40 AM | #8 |
Thank you for clearing that up for me. When I installed an 8BA in 40 Ford I welded ears to the stamped steel Merc bellhousing. Made shorter rods and sold the originals. Worked out fine and dandy.
03-22-2019, 12:31 PM | #9 |
Thank you! I think we have a solution.
I knew the fordbarn had the answer.
03-23-2019, 06:59 AM | #10 |
