Old 04-12-2024, 05:52 PM   #1
JCLEE
Default Business coupe oval windows?
So I'm pretty sure what I have here (correct me if I'm wrong) is a pair of oval windows from a '28 or '29 business coupe.
The outside nickel plated rings measure 7" X 11-3/4" and have some oxidization. The inner rings are steel painted black with some pitting. Only one nut is missing from the studs. The strap ends are all present and usable.
The glass is beveled and in good to very good condition with minor scratches and a couple small (less than 1/16") chips at the point of bevel.
Whad'ya think?
JCLEE is offline   Reply With Quote
Old 04-12-2024, 06:22 PM   #2
LeonardS
Default Re: Business coupe oval windows?
29 only. 28 didn’t have the oval windows.
LeonardS is offline   Reply With Quote
Old 04-12-2024, 06:23 PM   #3
700rpm
700rpm's Avatar
—Deleted my original incorrect response.—- see posts #4, #5 (corrected), & #6 #7 below.
Ray Horton, Portland, OR
Old 04-12-2024, 06:24 PM   #4
LeonardS
Originally Posted by 700rpm View Post
Only the ‘28s had oval windows. I have one, and the ovals are 14” x 9”.
I think you have that backwards.
Old 04-12-2024, 06:24 PM   #5
700rpm
700rpm's Avatar
Only the ‘29s had oval windows. I have one, (see my avatar) and the ovals are 14” x 9”.
Old 04-12-2024, 06:26 PM   #6
LeonardS
Only the ‘29s had oval windows. I have one, (see avatar) and the ovals are 14” x 9”.
Re-read your first post. You said 28’s had oval windows.
Old 04-12-2024, 06:26 PM   #7
700rpm
700rpm's Avatar
Youre right. I didn’t have my glasses on and mis-typed it. I’ve posted a correction. Size of windows is correct at 14”x9”.
Old 04-12-2024, 06:27 PM   #8
LeonardS
Youre right. I didn’t have my glasses on and mistyped it and posted a correction.
No problem.
Old 04-12-2024, 06:45 PM   #9
700rpm
700rpm's Avatar
You’re right. I didn’t have my glasses on and mis-typed it and have posted a correction.
Old 04-12-2024, 07:21 PM   #10
mercman from oz
mercman from oz's Avatar
1929 Ford Model A Coupe with Oval Windows - LeonardS
Old 04-12-2024, 07:40 PM   #11
rotorwrench
rotorwrench's Avatar
I've seen the bare frames before but I've not seen any with glass and what looks to be suspenders. Any of you 1929 Business Coupe owners have insight on those suspenders. The screws that hold the frames together are odd #5 type screws. My Sport Coupe back light frame uses the same odd screws.
rotorwrench is online now   Reply With Quote
Old 04-12-2024, 09:10 PM   #12
Pete W.
Are these correct? And what are they worth?
The owner wants to sell them.
Pete W. is offline   Reply With Quote
Old 04-12-2024, 09:46 PM   #13
J Franklin
J Franklin's Avatar
I doubt yours are correct for a Ford A. See Quote for correct size. Thank you 700rpm.
Old 04-12-2024, 09:46 PM   #14
alexiskai
alexiskai's Avatar
In the collection I'm liquidating we have a pair with glass but without brackets.
Old 04-12-2024, 10:03 PM   #15
700rpm
700rpm's Avatar
They are not correct.
Old 04-12-2024, 10:03 PM   #16
700rpm
700rpm's Avatar
Those that Alexiskai is showing look right. What are the dimensions?
Old 04-12-2024, 10:09 PM   #17
700rpm
700rpm's Avatar
The windows as shown by JCLEE in the original post are not correct for a 54A. 29 business coupe.
Old 04-12-2024, 10:13 PM   #18
700rpm
700rpm's Avatar
Pete W: Which ones are you referring to?
Old 04-13-2024, 05:26 AM   #19
mercman from oz
Correct Business Coupe oval windows - alexiskai
Old 04-13-2024, 05:34 PM   #20
rotorwrench
I've seen quite a few older car tops that have multiple back light glasses inset in side by side fashion.
The complete 29 Sport Coupes quarter oval windows are just mounted to the top material. The aft bow support is designed to leave that mounting area clear for the oval window. It mounts to the B pillar wood then curves to the bow support attachment. It then curves on down to the belt wood where it attaches.
The older business coupes and Sport Coupes just have a little brace on each side that secures that rear bow to the B pillars.
