Old 08-01-2021, 07:04 PM   #1
Gold Digger
Default Shorting pitman arm
I know this is not the AA truck forum but will shorting the pitman arm on a AA truck work as well as on the cars and pickups? I have two, a 30 and a 31 1 1/2 ton trucks that need some help on the steering wheel end. I have measured the arms on the trucks and on the cars and both seam to be the same lengths for pitman arms and the arm that the drag link connects to on the axel end are the same. Just wondering if anyone has done the short pitman arm on the AA's,
Gold Digger is offline   Reply With Quote
Old 08-01-2021, 08:01 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Shorting pitman arm
Your turning radius will increase. You may not like it.
Jacksonlll is offline   Reply With Quote
Old 08-01-2021, 08:06 PM   #3
J Franklin
J Franklin's Avatar
I'd leave it as it should be.
J Franklin is online now   Reply With Quote
Old 08-01-2021, 10:04 PM   #4
Pete
Pete's Avatar
The turning radius will stay the same. It will just take more turns of the steering wheel to get around a corner. In other words, the steering will be slower.
Old 08-01-2021, 10:14 PM   #5
Al 29Tudor
Al 29Tudor's Avatar
The turning radius will not increase because the radius is controlledby the king pin wedge nuts. The spindle will turn until it contacts the special domed nut and then stop.
Al
Al 29Tudor is offline   Reply With Quote
Old 08-01-2021, 10:24 PM   #6
MAG
MAG's Avatar
X2 on posts 4 & 5
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 08-01-2021, 10:56 PM   #7
bbrocksr
Al
Depends on how much you shorten it.
Bill
bbrocksr is offline   Reply With Quote
Old 08-02-2021, 12:23 PM   #8
Gold Digger
Thanks for the information. I have several extra pitman arms and I'll try shorting one about 1 1/2 inches and see if that helps about steering. This truck has good king pins and trust bearings but is hard to steer. Everything seems to be in good shape from sector to king pins. If shorting pitman arm don't help I can put the original back on.
Old 08-02-2021, 01:37 PM   #9
Pete
Pete's Avatar
There is always power assist as long as you don't have to keep original.
You don't have to modify the original steering with the assist system.
Old 08-03-2021, 07:14 AM   #10
jayvee34
jayvee34's Avatar
[QUOTE= This truck has good king pins and trust bearings but is hard to steer. Everything seems to be in good shape from sector to king pins. If shorting pitman arm don't help I can put the original back on.[/QUOTE]
If you shorten the pitman, arm will it shorten the lever action make it even
harder to steer? Just asking!!
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 08-03-2021, 07:26 AM   #11
kimlinh
Shortening the pitman arm will make it easier to steer. Just make sure everything else in the suspension is good.
kimlinh is offline   Reply With Quote
Old 08-03-2021, 07:51 AM   #12
jayvee34
jayvee34's Avatar
Thanks, Never to old to learn.
John
Old 08-03-2021, 11:41 AM   #13
bettlesr
bettlesr's Avatar
When I shortened mine, I first calculated it in AutoCAD and found that 1-1/4" let the stops on the arms at the wheels touch just before the box ran out of movement. This didn't widen the turning radius at all.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 08-03-2021, 12:28 PM   #14
Chris Haynes
Chris Haynes's Avatar
Easier and safer to buy a short pitman arm. https://www.snydersantiqueauto.com/P...earchByKeyword
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
