Old 07-30-2021, 07:25 PM   #1
1930artdeco
1930artdeco's Avatar
Default Sun visors for 57 wagon
Ok, does anyone reproduce sun visors for 57 wagons? All I see are for the closed cars. Barring nobody making them what are they made of-so I can make copies? I found some ‘finer board’ visors at a yard and am curious if these are what they are made of or is that the ‘core’ for the vinyl cover.
Thanks,
Mike
File Type: jpeg 2E9A53A5-ADED-4F64-AEB9-2C0978141E2C.jpeg (124.9 KB, 23 views)
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-30-2021, 08:31 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: Sun visors for 57 wagon
Do they look like this?
https://www.stockinteriors.com/Sunvi...p?Itemid=20929
I wouldn't think wagon visors would be any different from those for a sedan or Ranchero.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 07-30-2021, 10:15 PM   #3
1930artdeco
It is possible, the wagon is based on the custom frame. I just had the opportunity to get a set of visors with the fiber board base and before I spent the money I wanted to make sure. If not I will have to fabricate something.
Mike
1957 Country Sedan
Old 07-31-2021, 04:35 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: Sun visors for 57 wagon
Below are charts, usage depending on BODY CODE and TRIM CODE -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-31-2021, 10:07 AM   #5
1930artdeco
Here is another question, is there a shorter chrome piece that fits into a little holder by the rear view mirror? Or, does the spring keep them stiff enough not move when I position them?
Mike
1957 Country Sedan
Old 07-31-2021, 10:27 AM   #6
Dobie Gillis
These are '57/'58 sedan visors. As you can see, there is no provision to clip them into a holder near the mirror. Do you have the original bracket and arm assembly? The spring in the bracket should give enough tension to hold the visors where ever you place them. Also, you should be able to slide the visor, with some effort, laterally on the arm to block glare coming in the side window.
https://cgfordparts.com/wwwsectionfi...un_visors.html
Old 07-31-2021, 06:28 PM   #7
1930artdeco
Dobie, thanks for the link. I wasn’t sure if they were like the 60’s cars or not-apparently it is ‘not’. I have a pair of nice originals but just wasn’t sure if I should grab this set.
Thanks,
Mike
1957 Country Sedan
Old 07-31-2021, 07:03 PM   #8
Dobie Gillis
Glad to help...
Old 08-02-2021, 01:09 PM   #9
Gene F
Gene F's Avatar
Anyone know where I can get one of those license plate light assemblies (with the chrome cover/lense)? I need one for my 1957 Fairlane Skyliner.
Gene F is offline   Reply With Quote
Old 08-02-2021, 01:09 PM   #10
Gene F
Gene F's Avatar
FYI...it's the same one that station wagon used...
Old 08-03-2021, 09:18 AM   #11
1930artdeco
Are you talking about the little lights in the bumperettes? If so I know where a pair are.
Mike
1957 Country Sedan
