07-21-2021, 06:55 AM | #1 |
289 V8 oil pan removal
Has anyone been able to remove a 289 oil pan without having to raise the engine. Based on directions in the shop manual it can be done. The 64 Galaxie cross member goes directly under the pan. There is clearance but it's the oil pump/pickup.
The manual says after removing the pan bolt crank the engine as required to obtain clearance and remove the pan. |
07-21-2021, 08:47 AM | #2 | |
Re: 289 V8 oil pan removal
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-23-2021, 08:09 AM | #3 |
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
