Old 07-15-2021, 04:28 PM   #21
JSeery
JSeery's Avatar
Default Re: 65 Comets
Originally Posted by Lanny View Post
Here is a picture of the trans cross member from my '65 fastback.
I would guess the cross member in your Cyclone is similar, unless
you changed it when putting in the trans you are running.
You can see the bracket, for the flat bar to slide into, on my cross member.
Yes, it has been modified in that area, but the photo help a lot as to where it should locate!
Old 07-16-2021, 12:33 PM   #22
rotorwrench
rotorwrench's Avatar
It looks like there is plenty of beef there. I'm sure it needed all it could get.
Old 07-16-2021, 03:23 PM   #23
JSeery
JSeery's Avatar
There is a whole sub-frame all the way back.
Old 07-18-2021, 06:32 PM   #24
JSeery
JSeery's Avatar
Well, figured out the brake issue! All new brake parts a few years ago, but it had been setting. The wheel cylinders leaked brake fluid all over the inside of the brakes. What a mess, everything is corroded beyond belief. All new parts will fix the problem, but what a mess to clean up.
Old 07-19-2021, 11:27 AM   #25
rotorwrench
Sounds like stuff that sets too long in south Texas. I feel your pain there.
Old 07-19-2021, 12:40 PM   #26
JSeery
JSeery's Avatar
Total mess inside! But fixable.
Old 07-19-2021, 08:12 PM   #27
mercman from oz
mercman from oz's Avatar
Not a 1965 Mercury Comet, but a similar 1964 Mercury Comet Caliente Hardtop in Australia.
mercman from oz is online now   Reply With Quote
Old 07-19-2021, 08:15 PM   #28
mercman from oz
Interior of the 1964 Mercury Comet Caliente Hardtop.
Old 07-26-2021, 05:30 PM   #29
KULTULZ
KULTULZ's Avatar
Post Re: 65 Comets
Originally Posted by JSeery View Post
My current issue is trying to connect up the emergency brake. I found a source for the cable from the rear drums forward and the front cable up to the brake handle is there. I don't have the equalizer bar and rod that connects the two. A lot of searching has not turned up a source for these parts. So, I ordered 65 mustang parts and will attempt to use them. Was wondering is anyone knows what the differences would be? I assume it would be the length of the bar and maybe the curvature? Also can't find a photo of the original installation, which may or may not be helpful in my case, LOL.
Attached photo is off the internet, just an example of the components I am referring to.
If you still need it, attached is a partial ILL from the MERC MPC -
EDIT -
Additional Ill Added Below -
RELATED THREAD - https://www.fordbarn.com/forum/showthread.php?t=301630
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-27-2021, 04:38 PM   #30
JSeery
JSeery's Avatar
Thanks, I'm modifying 66 mustang parts, think it's going to work out good. Currently waiting on one part. Interesting that the 65 Comet was unique in this area, no apparent reason for it.
Old 03-19-2022, 03:44 PM   #31
AntonioR
Beautiful car!!
AntonioR is offline   Reply With Quote
Thread Tools
Display Modes
