Old 02-14-2020, 03:19 PM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Spark Control rod lubrication
Should the spring end of the control rod that goes from the steering column to the distributor upper plate be lubricated? The end of the plate arm has a ball fitting that came loose on mine..... Is there a way to keep it from coming loose? I am trying contact cement, but the thought crossed my mind that it might have less friction on it if I put a little grease inside the end of the rod.
Thoughts?
walkerlakeprinter is offline   Reply With Quote
Old 02-14-2020, 05:21 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Spark Control rod lubrication
all of the small Balls should be greased.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-14-2020, 05:49 PM   #3
Gary WA
Gary WA's Avatar
also two lube points on top of the linkage behind engine on each end at the top-
oil
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 02-14-2020, 05:52 PM   #4
walkerlakeprinter
Thanks. I thought so. Got 'em all greased.
Old 02-17-2020, 05:34 PM   #5
walkerlakeprinter
Well, contact cement didn't work to hold the ball stud on the distributor upper plate. Maybe I could solder it by heating it up and doing it like we do with copper sweat fittings? I'm trying to fix it without having to remove the upper plate and disturbing the timing.
Old 02-17-2020, 06:25 PM   #6
chrs1961815
chrs1961815's Avatar
This a frequent problem with upper plates. The rivet that holds the point stud on and the one that holds the control ball on are the two that are frequently loose. I have tried using a punch to flatten the rivet and tighten it more but with little success. I do not think solder would work, but it may be worth a try.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-17-2020, 07:02 PM   #7
walkerlakeprinter
I will try. I will let you know......but still open for more ideas.
Old 02-17-2020, 07:05 PM   #8
walkerlakeprinter
Today, I found out that the last time I retarded the spark, the rod had come off and pushed the distributor body off the base far enough to dislodge the connection to the #4 spark plug. The car started and ran, but sure didn't sound right. I saw a VERY healthy spark jumping more than an inch to the brass connector.
Old 02-17-2020, 07:18 PM   #9
Gary WA
Gary WA's Avatar
why not just replace the upper plate? Easy to do!
Old 02-18-2020, 07:06 AM   #10
chrs1961815
I would just replace the plate at this point as Gary said.
Old 02-18-2020, 05:18 PM   #11
walkerlakeprinter
Yup. That's what I'm going to do.....replace the upper plate. Everything failed up to now. I'm going to contact cement it again so I can start and move the car while waiting for the new upper plate.
