Old 07-17-2016, 05:08 PM   #1
Fillinjc
Fillinjc's Avatar
Default Spider Doesn't Reach Light Switch
Hi,
In my 1930 coupe, the spider does not reach into my light switch. The previous owner did not have a spring or retaining clip installed so I believe the spider would simply fail down into the switch. Could it be that I have the wrong length rod?
Thanks,
Jerry
Fillinjc is offline   Reply With Quote
Old 07-17-2016, 05:23 PM   #2
700rpm
700rpm's Avatar
Default Re: Spider Doesn't Reach Light Switch
That is the most likely explanation.
Ray Horton, Portland, OR
Old 07-17-2016, 08:08 PM   #3
Sunnybrook Farm
Sunnybrook Farm's Avatar
It looks about right to me, is the whole thing fitting together completely? It could just be a repo bulb that isn't matching up correctly, if you only put the top half on you can see how far the spider lacks of catching in the slots. It seems like I had to mess with mine a little but that was 35 years ago and haven't looked at it after I got it working.
Sunnybrook Farm is offline   Reply With Quote
Old 07-17-2016, 08:25 PM   #4
Fillinjc
Fillinjc's Avatar
By fitting the top half, the spider almost reaches the slots in the switch assy but not enough to catch. My lights stayed on after initial assembly because that is the way the switch went together. In order to be able to test drive this car tomorrow I removed the retainer clip. The spider engages and the switch is happy now. Obviously I will need to resolve this.
Old 07-17-2016, 08:34 PM   #5
SSsssteamer
SSsssteamer's Avatar
Originally Posted by Sunnybrook Farm View Post
It looks about right to me, is the whole thing fitting together completely? It could just be a repo bulb that isn't matching up correctly, if you only put the top half on you can see how far the spider lacks of catching in the slots....".
I had the same problem too. I found an original light switch bulb at the swap meet for $2 that allowed the spider fit like it should..
SSsssteamer is offline   Reply With Quote
