Old 01-22-2012, 01:13 AM   #1
jimmyz80
Default Identify original headlight reflectors?
What's an easy way to tell whether I have original reflectors, or repros? I'm guessing they are original, since the finish is very poor, and there is some sort of reflective plastic insert that is sitting in front of them. Was it common during 1970s restorations to put some sort of reflective insert into the headlights, instead of re-silvering?
The reason I ask, is I'd like to get the reflectors re-silvered, but only if they are original.
jimmyz80 is offline   Reply With Quote
Old 01-22-2012, 01:32 AM   #2
Arlen
Arlen's Avatar
Default Re: Identify original headlight reflectors?
On the originals I've seen, the silvering is in very poor shape and you can see the brass coming through. Also some that I've seen on the outer lip where the cork gasket sits, I've seen a ford script but very light. I met a guy at last Hershey who does the silvering for $60 a set if your interested. Beautiful work
DMAFC
Arlen is offline   Reply With Quote
Old 01-22-2012, 02:02 AM   #3
jimmyz80
Hmm I'll pop them out tomorrow and see if I can make out a Ford script anywhere. As far as the cork gaskets go, does anyone sell replacements? I took a quick look around online and didn't turn up anything, but I may have been searching for the wrong words.
I'm thinking I may go the nickel, then Uvira/Aluminum route.
Old 01-22-2012, 10:27 AM   #4
Steve Plucker
Try Brattons or any other Model A/AA Ford parts house...see STICKY above for information.
Pluck
Old 01-22-2012, 10:38 AM   #5
30Tudor
30Tudor's Avatar
I think i have a pair of originals. On the rim where the gasket goes, there is a marking saying "Ford Two-lite"
See also other posts on re-silvering.
30Tudor is offline   Reply With Quote
Old 01-22-2012, 01:13 PM   #6
Charlie Stephens
I have four reflectors that appear to have the right amount of patina but I am trying to tell if they are original. I can't find a script on any of them, did all of the originals have script. Two have notches at 12 and 6 oclock and two do not. Are the ones without the notches aftermarket? I keep hearing bad things about the shape of many of the current repros, did the replacement parts from the '30's and '40's have problem?
Charlie Stephens
Old 01-22-2012, 01:58 PM   #7
jimmyz80
Pluck
Tried... I can't find any gasket that looks like it's meant for this position in the headlight. The stickies in this forum don't help either, since they are just links to parts houses and plating companies. I already have all of that info. What I don't have, is the knowledge of how to tell an original from a repro.
Old 01-23-2012, 12:00 AM   #8
30Tudor
30Tudor's Avatar
My guess is if they had been silvered they were probably "orginals" NOS or NORS. The repros you get now are chrome plated.
Have a look at Marco's site. http://abarnyard.com/workshop/lamp_focus-2.htm to see the difference between the originals and the repops.
The part number for the gaskets at Brattons is: Part #18120.
HEADLIGHT LENS GASKETFor Year(s): 28-34
Rubberized CORK.
Part #18120 HEADLIGHT LENS GASKET $ 3.25
Old 01-23-2012, 01:30 AM   #9
Russ/40
Russ/40's Avatar
I would like that info on the plater if you don't mind. You can PM me if you don't want to post it.
Old 01-23-2012, 08:51 AM   #10
John Duden
John Duden's Avatar
there is one on the ford garage, telling about the differences between original and new
John
John Duden is offline   Reply With Quote
