Old 10-14-2020, 01:32 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Gap at wishbone to bell housing
I can't seem to get rid of the gap at the wishbone to bell housing area.
Is this gap normal or should I be concerned?
If so, how do I fix it?
I dont remember seeing this gap in the past.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 10-14-2020, 01:47 PM   #2
Ruth
Default Re: Gap at wishbone to bell housing
Look just like mine, not a problem.
Ruth
Old 10-14-2020, 04:48 PM   #3
john in illinois
john in illinois's Avatar
That means your ball is not worn out-a good thing
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 10-14-2020, 05:38 PM   #4
GRutter
GRutter's Avatar
The gap means that the bottom clamp is under spring pressure to hold the wishbone ball in place, which is normal.
If you didn't have any gap remaining... that's when you start having a problem.
GRutter is offline   Reply With Quote
Old 10-14-2020, 07:47 PM   #5
Actually there are two gaps.
One between the bell housing and the inside, upper cup.
Then one between the upper cup and the lower cup.
Are you sure that is normal?
Old 10-14-2020, 08:34 PM   #6
Joe K
Joe K's Avatar
The ball retainer assembly is "spring loaded." The ball seat (part directly on the bell housing) should be "close" as in touching. The ball retainer (part on the lower side of the ball) is "free floating" and held against the wishbone ball by retaining springs.
The ball retainer has larger holes than the bolt by a considerable amount. There are actually annular "sleeves" which the ball retainer slides over: the springs are outside of these and on the lower side of the ball retainer.
The nuts are held from compressing the springs "solid" by these sleeves. The proper setup has the nuts as tight as they can be, the compressed spring with small gap between the turns, and a small gap between ball seat and ball retainer.
It is possible if there is considerable downward force on your wishbone that it could compress the springs, cause the ball retainer to drop, loosen the contact between the ball and its ball seat, and a gap to form between the ball seat and the bell housing. This I would consider unusual. And possibly a reason to replace at least the springs which in time may lose their compression.
This quite a bit different from the aftermarket ball caps which when assembled are "solid" - and the make-up made in the rubber ball.
Joe K
Shudda kept the horse.
Old 10-15-2020, 02:12 AM   #7
john charlton
john charlton's Avatar
From your picture it looks to me that the bottom retainer is cast iron not pressed steel . This is the aftermarket rubber ball setup which I myself am not a fan of . With the all steel setup you can see what is going on with the hidden rubber ball you cannot . The reason that the rubber ball setup is used is because of excess wear on the radius ball (gone oval) If the ball is oval the parts houses sell a shaped washer to take up the slack . If it were my car i would ditch that setup and go back to standard .
John still in thanks to Covid 19 Suffolk County England .
Old 10-15-2020, 02:20 AM   #8
John,
I have the original set up.
The upper cup is cad plated.
See picture from Brattons online catalog.
Old 10-15-2020, 09:30 AM   #9
john charlton
Looking again I can see OOOOPS !!!
John in same place same weather .
Old 10-22-2020, 04:04 PM   #10
Miles in MN
Miles in MN's Avatar
The sleeves are supposed to hold the upper cap firmly against the bottom of the bell housing. I would look for some interference between the upper cap and bellhousing that is preventing the cap from seating tightly at the bellhousing.
Miles in MN is offline   Reply With Quote
