Old 03-26-2020, 11:11 PM   #1
slumlord44
Default 64 1/2 Mustang catpet
The 64 1/2 and early 65 Mustangs had carpet that only went to the bottom of the inner rocker panel. Later ones had the carpet extend up the inner rocker and under the aluminum sill plate. The early ones had a piece of vynil glued to the inner rocker pane. I have an early 65 with the 64 1/2 carpet from the factory. Haven't found a source yet. Everyone has the later carpet. Only option I can think of is to have and upholstrey shop trim a set and bind the edge. Anyone aware of a source for the early carpet?
slumlord44 is offline   Reply With Quote
Old 03-27-2020, 08:46 AM   #2
Marcus
Marcus's Avatar
Default Re: 64 1/2 Mustang catpet
Slumlord44: I have searched diligently, to no available. My early 65 had the same issue and the solution was as you stated: upholstery shop. However, shop around to find one with older, experienced craftsmen: many of the younger ones want to take shortcuts.
Alternatively, give Auto Custom Carpet in Alabama a call: they may have a lead or other options for you. 800-352-8216. Website: accmats.com.
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 03-27-2020, 08:38 PM   #3
paul2748
paul2748's Avatar
Maybe call SMS Auto Fabrics. Not sure they handle carpet 503-263-3535
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-04-2020, 12:22 PM   #4
barnstuf
Just to help establish a time frame for this change I had a new Mustang on order, it was built in September and I took possession of it from my Ford dealer on Sept 30,1964. The carpet is under the sill plates. Yes, I still own it!
barnstuf is offline   Reply With Quote
