Old 11-21-2015, 04:22 PM   #1
fordfun
fordfun's Avatar
Post Oil Pan Plug - 7/8"
Last week, after running the Coupe for the last time this year, I removed the drain plug and let the oil drain for a few days. Today I decided to replace the copper gasket before reinstalling the plug and refilling with oil. I find that the replacement gaskets provided by the vendor are 3/4" ID and my plug is 7/8" OD x 16 threads per inch.
Do I have a non-standard size plug, or are the gaskets incorrect? If the plug is incorrect can you suggest a source for 7/8" ID gaskets for the plug?
Thanks - Bill
fordfun is offline   Reply With Quote
Old 11-21-2015, 05:19 PM   #2
colin1928
colin1928's Avatar
Default Re: Oil Pan Plug - 7/8"
1928 plug was larger than the 29/31 plug
colin1928 is offline   Reply With Quote
Old 11-21-2015, 05:21 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Hardware stores and local auto parts stores should have an assortment of copper gaskets. It's rare that I need to buy a new one rather than reuse the old one.
Old 11-21-2015, 05:21 PM   #4
colin1928
colin1928's Avatar
Local hardware supply should have a range of copper washers
Old 11-22-2015, 12:57 AM   #5
jw hash
jw hash's Avatar
Don is correct use a spark plug gasket. all Model A spark plugs are 7/8"
jw hash is offline   Reply With Quote
Old 11-22-2015, 09:20 AM   #6
fordfun
fordfun's Avatar
Thanks for the good suggestions. The plug may well be part of a '28 pan. The car was represented as a '29 Sports Coupe, and I suspect it either was significantly altered over the years or may have been assembled from parts of various other cars (Mod. B head and carb, etc.). I haven't been able to locate a frame number, but it may be hidden under the cab.
