Old 08-17-2014, 01:18 PM   #1
Dbbc
Dbbc's Avatar
Default Backfire
Aloha,
just came back from my Sunday drive, and the car is backfiring quite a bit. And the further I advance the spark the louder the backfiring is. Great to see pedestrian jump, but would like the car to run smoothly. This my first Model A and not quite sure what to do. I also have th GAV turn at least an half to 3/4 turn or the car stalls.
The backfiring happens also when I am going down hill when releasing the accelarator.
As always any help would be greatly appreciated.
Mahalo
Dbbc is offline   Reply With Quote
Old 08-17-2014, 01:49 PM   #2
goodoldvic
goodoldvic's Avatar
Default Re: Backfire
Could be lean mixture, intake leak, exhaust leak a hole in the muffler will also make it backfire. Maybe clogged jet Just some possible causes... good luck
goodoldvic is offline   Reply With Quote
Old 08-17-2014, 01:49 PM   #3
rocket1
I would first check the timing,if the car has not been driven in a while it might be a stuck exhaust valve,or maybe a bad condenser.
rocket1 is offline   Reply With Quote
Old 08-17-2014, 02:36 PM   #4
springerpete
springerpete's Avatar
change the condenser and see if that solves it.
springerpete is offline   Reply With Quote
Old 08-17-2014, 09:45 PM   #5
Dbbc
Dbbc's Avatar
Lean mixture creates the backfiring? Should I enrich the mixture by adjusting the carburetor?
Old 08-17-2014, 09:57 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You're already where you should be on the gav, so the lean mixture is probably caused from an intake leak. Or an exhaust leak , sucking air in and igniting on deacceleration, which isn't a lean mixture problem. HAve you pulled your plugs to see how they look? They can provide some good information.
Old 08-17-2014, 10:43 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Timing, the rubbing block will wear closing the points.
Old 08-18-2014, 05:59 AM   #8
CountrySquire55
CountrySquire55's Avatar
I had a very similar problem with my 31 Slant Town Sedan going on a club tour. Turns out it was debris (dirt, not rust) in the carburetor from a tank of contaminated gasoline. Ended up removing the jets, cleaned and blew everything out with compressed air, then my car ran fine.
CountrySquire55 is offline   Reply With Quote
Old 08-18-2014, 07:35 AM   #9
Chris in CT
Hi Dbbc, Lean mixture. Your car stalls when you close the GAV, so that is the giveaway. I think your problem is as Country Squire describes above. Happy Motoring!
Chris in CT is offline   Reply With Quote
Old 08-18-2014, 04:51 PM   #10
fordfun
fordfun's Avatar
I had the same problem going down a steep hill today in 2nd gear. The problem eased after shifting to 3rd. How do you check for an exhaust leak?
fordfun is offline   Reply With Quote
Old 08-18-2014, 11:30 PM   #11
Dbbc
Dbbc's Avatar
Aloha,
Thanks for all the info. It could very well be the exhaust. I removed the manifold in order to paint the block. I should probably have replace the gasket, but I did not have one on hand.
Will try that first and clean the jets.
mahalo
Old 08-19-2014, 07:25 AM   #12
fredski
fredski's Avatar
exhaust leak is easy to find . start car with cold engine and feel around
the manifold . you will feel the leaking air.
fredski is offline   Reply With Quote
Old 08-19-2014, 08:15 AM   #13
tbirdtbird
lean. clean carb. open GAV as much as you need to make it run, every carb is different
the crapahol gas they sell now does bad things to a carb/tank. Do not fill tank unless going on a tour. Keep tank no more than 1/2 full, and drive as much as you can so gas doesn't go stale.
We sure didn't have this problem in the '50s....gas was real gas! Unpolluted fuel!
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-19-2014, 10:05 AM   #14
JD 1931
JD 1931's Avatar
sounds like it is lean, adjust or replace jets in carb.....
JD 1931 is offline   Reply With Quote
Old 08-19-2014, 06:08 PM   #15
fordfun
fordfun's Avatar
Fredski -
Thanks for the response. I'll try that.
Old 09-17-2014, 05:18 PM   #16
fashion frank
I am having the same problem but my 31 just died after the backfire.
Here's what happned .
I just bought the car ,it is ( or was) turn key ready.
Brought it back from PA, drove it around the hood twice with no problems.
I know how to drive a standard but got my model a start up and shifting education from youtube .
Now the last time I took it out again, very close to home just to get the oil hot enough to dump, I noticed it was almost stalling every time I came to a stop .
So I pulled off the main drag , adjusted the choke /carb jetting knob a bit to try to get it to run leaner or as I hoped to stop it from hesitating at a stop.
Well that was a mistake because I then pulled back out onto the main drag and went about ten feet ,it backfired ,drove " rough" for about another ten feet and then died.
I managed to pull into a side street and had to have it towed the two blocks from my house.
Before I had it towed ,I tried to restart it , it would just crank ,but not turn over and there seems to be a smell of gas so I checked and there was in fact a good amount of excess gas , I assumed that I flooded it ,so I waited a while tried it again and had no luck.
A few days later I went out to the garage and tried again but same thing cranking but no turning over,I made sure the choke/jetting knob was "turned " all the way down , still no go.
I have since ordered a set of points and condenser that are on their way.
This Sunday is my first Model a club meeting and I am hoping someone will help me out and get it running again.
I am sure it must be something small as it was running like a sewing machine before this happned.
Does anyone here have any idea what might have happned and or what might be the problem ?
Thanks in advance ,Frank
P.S. I also changed the plugs figuring they were fouled and they were in fact black with soot but still no go and now no matter were I "set" the choke jetting knob still nothing.
fashion frank is offline   Reply With Quote
Old 09-17-2014, 06:42 PM   #17
whirnot
whirnot's Avatar
Depending on the temperature and humidity that can be a bad habit. The more room there is in the tank, the more room for condensation. I have had do thaw out many a frozen fuel line for this very problem. The solution besides keeping it full, Fuel antfreeze, which is alcohol
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 09-17-2014, 06:52 PM   #18
Tom Endy
Tom Endy's Avatar
As the rubbing block on the ignition points wear they close up from the original setting, 018-022. This changes the timing. Reset the points to where you originally had them set and it will restore the timing to where you originally had it set.
Tom Endy
Old 09-18-2014, 12:45 AM   #19
tbirdtbird
go ahead and fill it and let it sit and be ready for the consequences. The condensation concept is overrated and implies there is air moving in and out of the tank. I have never had water in fuel from 'condensation'. If there is water in there then the fuel came with water
'31 180A
Old 09-18-2014, 01:16 AM   #20
Chuck Sea/Tac
I never have a problem with filling up the tank. Even if it takes several months to run it out. If it's going to be 3 or more months to run it out, then I'll add stabil. Never have a problem. Same with my mower gas. Stabil, and it lasts for 6 months. Did the same to my sons bike all winter. Started right up 6 months later when he came to get it.
