11-26-2021, 07:55 PM | #1 |
Steering wheel Resto
I acquired a beautiful banjo wheel with very cracked and missing plastic.
Do any of you have a recommendation on a steering wheel restoration shop? I see several online but prefer knowing someone got a decent job done. Sent from my iPhone using Tapatalk
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird |
11-26-2021, 09:17 PM | #2 |
Re: Steering wheel Resto
Do it yourself. It is not all that big a job. Time consuming, but I really enjoyed doing the one on my Avatar. I used PC7, not JB Weld.
Do not use a primer as you don't want primer showing through with a little wear. several coats of "top coat" sanded between coats.
11-26-2021, 10:20 PM | #3 |
steeringwheelkris.com does beautiful work! Restoration or custom, he can do whatever you want and can handle re-chroming, if needed.
11-26-2021, 11:32 PM | #4 |
I used PC-7 on my '41 and '60. works great
11-27-2021, 12:18 AM | #5 |
There’s too much missing for me to repair cracks. I’ve got enough busy work on other vehicles.
After 35 years of building cars I’ve learned to farm a few things out. I’ve even employed a young welder to do things I can do myself. He’s fast, great, and priced right! Sent from my iPhone using Tapatalk
11-27-2021, 04:17 PM | #6 | |
Absolutely top-notch work.
Seabright Hot Rods |
12-06-2021, 12:39 PM | #7 |
A few months ago Bob Monetti did a fantastic job restoring a pitiful '34 steering wheel that I have. Google "steering wheel bob" or his web site at https://www.steeringwheelbob.com
-Mike |
12-06-2021, 01:03 PM | #8 | |
12-06-2021, 05:23 PM | #9 |
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
12-07-2021, 12:27 PM | #10 |
What I paid won't mean much because the cost is based on how much work/repair that a steering wheel requires. I sent Bob photos of the wheel and we subsequently talked via the phone about the work that would need to be done. In the end, the invoice was about 25% less than his estimate and I received it 2 weeks sooner than scheduled.
To further this point, I have a second wheel and his estimate for the second wheel is significantly less than the first wheel. Again, it all depends on condition. I suggest that you send Bob photos and have a conversation with him. -Mike |
12-09-2021, 06:14 AM | #11 |
I used PC-7. Seemed OK at the time, but a lot of cracks appeared about 6 months after finish. Not sure if maybe I did something wrong, or if the wheel was past saving.
12-09-2021, 09:06 AM | #12 |
I restored my 34 wheel which had cracks on all three spokes on the hub and at the rim, several pieces missing. I ground out all the cracks down to the steel and filled up with JB. After hardening and blending in the JB I used a small bit of filler to get a perfect surface. To paint that wheel evenly without any chance of runners, I built a contraption with a little electric motor driving a big bicycle wheel through a 1/8" pin - so the speed was reduced a lot. The bicyle wheel was coupled to the steering wheels hub and thus it slowly rotated. I just needed one thick coat to have it in like new condition again - no runners and high gloss everywhere.
Until now no cracks or blisters after 4500 km this year. |
12-09-2021, 12:16 PM | #13 |
In my opinion I would second a shout-out to Bob Monetti @ steeringwheelbob.com. He is second to none. Did three wheels for me and everyone is museum quality. None of mine had chroming involved and were in the $700 to $800 range. I have no regrets and would go back to him in a heartbeat.
12-12-2021, 12:58 AM | #14 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-12-2021, 01:11 AM | #15 |
here's my contraption I made for painting wire wheels.
lots of angles to cover with wires, and while 3 coats on any given part are fine, wire wheels should have 5 to cover it all....before I made this. It turns a 5 rpm, no skill required, practically pour the paint on, no runs, no orange peel, no dry spots. I have since made many adapters for this to spin small parts, or even clean gas tanks. |
12-12-2021, 04:36 PM | #16 |
GB - nice to hear you are inspired! The fine machinery of cas3 is the luxury variant of my cobbled together apparatus. As long as you have a slow and steady turning motion you can´t do wrong when painting steering wheels or other rotating objects.
