11-12-2021, 02:52 PM | #21 |
Re: Mounting ‘Tubman’ condenser on dome distributor
11-12-2021, 03:44 PM | #22 |
Would this be okay to mount directly under the bolt? Or would I have to make a “lug” such as ‘Lawrie’ stated above. Also would anyone know where to get a large p clamp to fit a 5/16s as well as it being bare metal I seem to can only find insulted clamps.
11-12-2021, 05:24 PM | #23 |
If it was me, I'd just find or buy a piece of flat stock. Drill a hole, bend to shape or vise versa and your good to go. Either that or get one with the insulation and remove the insulation.
Sometimes, ingenuity gets in the way of sense and sanity. |
11-12-2021, 05:51 PM | #24 | |
oops; slow to respond. |
11-12-2021, 06:23 PM | #25 | |
Could you give me an example of a ‘tab’ I understand what you mean but I’m struggling on the tab part. |
11-12-2021, 11:31 PM | #26 | |
A flat piece could be attached with the smaller hole to the left or right of the 5/16" bolt; the length could be varied to suit the desired location of the condenser. If you wanted to attach the P clamp directly above or below the 5/16" bolt a Z bend could be made so the P clamp and condenser clears the 5/16" bolt. You also put a 90 degree bend in it with the 3/16" hole extending straight forward from engine. The flat bar material could be anything that would support the weight along with taking into consideration that it is mounted directly to and subjected to the vibrations of the engine. I usually saw a hunk off a piece of 12 ga plate; but also use the 1/8" flat bars from the metal piece displays at the hardware store. |
11-13-2021, 04:26 PM | #27 | |
I don’t have the equipment to do this, so I plan to mount directly under the bolt that is there. I believe that will be sufficient right? |
11-13-2021, 05:14 PM | #28 |
Here is how I mounted mine before I went back to the original type coil, it’s just mounted to an angle bracket from Home Depot or your local hardware store.
11-13-2021, 07:08 PM | #29 |
That's really a good idea. I got an email from Chris (the O/P) saying he was going to go to Lowe's to try to find a 5/16" "P-clamp. I think he may be better served looking at the miscellaneous brackets (such as the one you used) in the hardware section.
11-13-2021, 07:24 PM | #30 | |
Wow! Y’all on here are smart! That’s a good idea, I will just have to make sure I can clear the side of the coil so the holes will line up. I had to do some minor adjustments to other clamp to try and get it to fit. |
11-14-2021, 05:06 PM | #31 |
Did this on my car
11-14-2021, 05:11 PM | #32 |
You might be able to file the hole in the clamp out to 5/16". The condenser does not have to be mounted directly at the distributor, so on that bolt might be an alternative.
Edit: replied before seeing the replies on page 2. |
11-14-2021, 05:43 PM | #33 |
That looks good! How did you do this? I took the idea from above and got a angled bracket. I had to cut the sides to get it to fit in the beside of the coil. Now I have to get another screw to mount the condenser because I forgot it at lowes today. Not the purtiest but if it gets her running I’m more than happy. What do y’all think? Yes or no? |
11-16-2021, 05:51 PM | #34 |
Well y’all, here it is. Got a Allen screw through the cavity locked in with a nut and the lead to the screw locked in by another nut. Hopefully this makes a good enough connection with the lead. Plan to try and start her tomorrow as I have left my battery in my moms car.
11-16-2021, 07:59 PM | #35 |
Well there ya be, Good Job! That'll work just fine.
11-16-2021, 08:14 PM | #36 | |
Well Chris, you have been getting a lot of good suggestions and help from the great members here on the Fordbarn. We are all pulling for you and hoping you get your engine running so you can go have a nice drive in your '34... good luck .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
11-17-2021, 05:32 PM | #37 |
Well everyone, tried to start it today and I didn’t get a start or even a stutter. If anyone would like to see a video of me trying to start it and maybe listen for something I don’t hear please let me know and I will get your email and send it over.
11-17-2021, 08:16 PM | #38 |
First step, make sure you are getting power to the coil when the ignition switch is turned on, if not troubleshoot and fix. Second step is to check if there is any spark when cranking the engine over; test by pulling a wire off a spark plug and holding (with something insulated like rubber grip pliers or wooden clothes pin) the end about 1/16 from the spark plug. If you get spark, that's not your problem. If no spark report back and we can help figure out why.
11-17-2021, 08:28 PM | #39 | |
When I checked before trying to start I had about 4.5-5 volts at coil with switch on. The way I checked spark was by pulling the whole plug out and grounding on a head bolt. I got no spark from here but I could have possibly not had it grounded good. Something else I was thinking about is I might not have a good connection on the coil from the lead of the condenser. It’s hard to tighten the nut but I thought I had it tight enough with two nuts. |
11-18-2021, 12:13 AM | #40 |
Chris,
I have just finished going through all of your posts, and have come up with a couple of concerns. In your first post, it says that "In preparation for starting it, we have had the distributor rebuilt with a new condenser, we have had new Auto-lite 386 spark plugs put in as well as spark plug wires, cleaned the gas tank, fuel lines, and original fuel sender, and finally installed a new fuel pump". I see later that you got a new coil from Skip. One question that was never answered is "Who rebuilt the distributor?". If it was done by someone unknown at some undetermined time in the past, I would suspect it and I am afraid your only choice is to send it out to someone reputable and have it done again. Also, I see that the tank, fuel lines, fuel pump, and carburetor have all been replaced, but in some of your later posts, it seems that you are back to hand feeding fuel down the carb throat. I think it would be a very good idea to see what is wrong with the fuel system and correct it. Dumping fuel down the carb may work for some, but if you have any other problems, it may be enough to keep the engine from starting. Stick with it; we'll get it going. When you get a chance, email me the video. |
