12-07-2021, 02:14 PM | #1 |
Note to Matt at iron trap garage
On your fathers Ford coupe. Try swapping exhaust manifolds side to side.
12-07-2021, 08:01 PM | #2 |
Re: Note to Matt at iron trap garage
Add this to the comments on Matts video
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-09-2021, 10:29 AM | #3 |
This requires an adapter plate, but works quite well. Did this back in the 60's for dual exhaust.
G |
12-09-2021, 06:44 PM | #4 |
You can private message him click on contact info. |
