08-21-2012, 03:37 PM | #1 |
97 carb
Has any one sleeved the accelerator pump well?
Bruce Works good Lasts long time |
08-21-2012, 07:58 PM | #2 |
Re: 97 carb
No one?
Well I bored it with a new 11/16" end mill. Then I turned a piece of yellow brass .625" id, and .698" od. Will finish the od tomorrow. Pictures I hope. Bruce Works good Lasts long time |
08-22-2012, 12:49 PM | #3 |
Re: 97 carb
This should be interesting...
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
08-22-2012, 12:51 PM | #4 |
Re: 97 carb
So...what is going on here? Damaged casting?
08-22-2012, 02:28 PM | #5 |
Re: 97 carb
There were corrosion pits in the lower 1/2" of the well.
The sleeve is in and the slot cut down to original depth. Looks good to go. I will try to post pictures when it is finished. Bruce Works good Lasts long time |
08-22-2012, 04:04 PM | #6 |
Re: 97 carb
The sleeve is in and the slot cut down to original depth. Looks good to go. I will try to post pictures when it is finished. Bruce Works good Lasts long time This is what happens when people use 97's to collect rain water for their indoor plants... If you're successful with the repair - and willing - I might send you a few from my bonepile.
08-30-2012, 08:10 PM | #7 |
Re: 97 carb
Here are some pictures. Ready to cleanup and reassemble.
Thanks to Uncle Max for the help Bruce http://s1118.photobucket.com/albums/k617/cbrucew/ Works good Lasts long time |
08-30-2012, 08:46 PM | #8 |
Re: 97 carb
Impressive job-you have real tallent.
08-30-2012, 10:29 PM | #9 |
Re: 97 carb
Excellent!
Bill |
08-31-2012, 04:15 PM | #10 |
Re: 97 carb
Cleaned up everything, and reassembled. From the speedway master 97 rebuild kit
I was unable to use; jets needle valve and seat Accelerator pump $43.00 for gaskets? Its all good. Starts good, runs, and does not leak. Bruce Works good Lasts long time |
09-01-2012, 09:50 AM | #11 |
Re: 97 carb
Fantastic save. Are you going to be doing any for customers??
[QUO[/QUOTE]no matter where you are,or where you're at, there you are... |
09-01-2012, 10:50 AM | #12 |
Re: 97 carb
Nice repair!
09-01-2012, 11:57 AM | #13 |
Re: 97 carb
09-01-2012, 12:19 PM | #14 |
Re: 97 carb
Hey Bruce,
Wow...talent/skill! You retire slightly before I did. I still wish you lived closer..mabe some of that skill would learn by osmosis.eh ! Very nice work. If you need a nice 97, let me know! Regards |
06-10-2015, 03:59 PM | #15 |
Re: 97 carb
GREAT JOB !!
how much interference fit on the sleeve to carb body, Did you use any type of sleeve setting compound? or just a dry press fit? Fordestes |
06-10-2015, 07:40 PM | #16 |
Re: 97 carb
Jut saw your post and you are right on the money cmbrucew the brass works great for a long term fix.Its harder than the die cast and easy to machine.
06-10-2015, 07:53 PM | #17 |
Re: 97 carb
Fordestes I don't remember. but I did put a light cote of locktite on before pressing in. Much easier to buy a body from Uncle Max. Bruce
06-10-2015, 09:30 PM | #18 |
Re: 97 carb
Told the misses about this sleeving business. She's not interested.
06-10-2015, 09:46 PM | #19 |
Re: 97 carb
OOOoooooooooo!
Alan |
