02-18-2022, 04:39 PM | #1 |
oil pump question? stock 28 motor
i am using the early style pump housing, i have undercut the new repo pump drive shaft to the same dimensions (0.0408) that the originals were. its ready to go together.
the new pump gears are about .003" longer than the originals that came out. this means they touch the cap and the pump will not rotate freely. question, i see that some suppliers sell a gasket for the bottom plate and am wondering if this is why that gasket is available? and do you folks use this gasket when doing a pump rebuild? when i take the pumps apart i don't find gaskets in them.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." Last edited by old ugly; 02-18-2022 at 04:48 PM. |
02-18-2022, 07:04 PM | #2 |
Re: oil pump question? stock 28 motor
I've seen pumps with and without a gasket. My normal procedure is to use a flat surface and a sheet of wet and dry paper and run the pump complete with gears over it till I get a shiny surface on the gear and the pump body. That means the gears just touch the end plate. I expect some would assemble like that but I use a thin piece of paper to make a gasket about 0.0015" thick, just to allow a little clearance for the gears. If the end plate is worn on both sides, I buy a new one.
02-18-2022, 08:30 PM | #3 |
02-18-2022, 08:44 PM | #4 | |
thanks ou
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-19-2022, 11:09 AM | #5 | |
i have some real thin gasket material i think will work. i searched to find new style shaft in old style pump body and found no one that sells or undercuts a new shaft for the old pump. i have undercut on the lathe my new shaft. do folks just put into the pump the fatter shaft and hope for the best? thanks ou
02-19-2022, 11:31 AM | #6 |
The end play on the gears itself in relation to the housing and cover are not as critical in this application. The original Model A is just transferring oil at very low pressure if any at all. Leakage around the end of the gear is minimal. If you are trying to pump 50 psi, it may be a little different. As for the shaft diameter/housing dia. The original housing was a .562~ diameter with a .500 shaft. that equates to .052 sq" area to transfer the oil. equiv to a 1/4" hole. The service bulletin mentions reducing the shaft diam to increase this area in the original pump housing. Later housings had .625 diameter and the area is greatly increased. approx .110 sq" area. equiv to 3/8" hole. There are other factors such as the length of the housing and the surface finish to affect the actual transfer of the oil. For example, the pumps I build for the Mod"A/B" are V8 pumps (larger gears) with the integral pressure relief, a billet alum housing into the block with reduced shaft. These are meant to be used in full pressure oiling systems and I limit the pressure to 30 psi. Best, John
As Carroll Smith wrote; All Failures are Human in Origin. Last edited by johnneilson; 02-19-2022 at 11:33 AM. Reason: correction |
02-19-2022, 11:56 AM | #7 | |
so,,, with the new style shaft in the old pump housing there is enough sq " to transfer all the oil needed for the stock gravity fed oiling system which is final fed through a 1/4" tube in the oil gallery? is that correct? thanks ou
02-19-2022, 12:39 PM | #8 | |
John
As Carroll Smith wrote; All Failures are Human in Origin. |
02-19-2022, 01:43 PM | #9 | |
i don't know if any of that was caused from lack of oil. (maybe the rear main damage?). never the less i want to minimize the risk, im checking as much as possible. thanks ou
02-19-2022, 02:45 PM | #10 |
If the pump is assembled with no gasket but still turns freely then it will work with no gasket. If it's making contact between gears & plate and has any resistance at all then the gasket will relieve the bind if it's thick enough. Most available gaskets are pretty thin.
Check for leakage of the plug for for the cross drilling. I recently found one leaking and will have to solder it with silver. Some may be welded but I don't know all the ways that Ford plugged the open end of that feed port. Last edited by rotorwrench; 02-19-2022 at 07:33 PM. |
02-19-2022, 05:41 PM | #11 | |
i am going to clean it dry it then fill that cavity with gas to see if any wet spots occur. if i get a leak i will have to remove and resolder on the cover. thank you
02-19-2022, 07:41 PM | #12 |
Thanks for explaining how those early ones are set up. I've heard of the soldered cover but wasn't sure what all was soldered without looking at one. Some had the clips to hold the cover but I've only seen the photos of those. If it leaks in there it would be difficult to see it with the screen cover on there. The pump I have is one of the late types from a 1931 engine so everything is held by screws. The plug is more like a rivet but it didn't cover the hole. If I shine a bright LED light up into the feed bore I can see the light coming around part of the edge of the plug that is open. A person could also put solvent in the feed hole while holding he pump on an angle toward the plug and see if it leaks out.
02-19-2022, 08:09 PM | #13 | |
02-22-2022, 11:21 AM | #14 |
[QUOTE= A person could also put solvent in the feed hole while holding he pump on an angle toward the plug and see if it leaks out.[/QUOTE]
i plugged the top holes turned the pump upside down and filled it with gunwash/lacquer thinner (which will find its way through the tiniest of holes). no leaks at the soldered up cross drilled hole. i am glad you found this issue. and i am glad i don't have to try to fix my pump there. thank you
02-22-2022, 12:57 PM | #15 |
Having all that soldered stuff would definitely complicate the process. I'm glad to hear it's OK.
