Old 04-12-2019, 10:57 PM   #1
M2M
M2M's Avatar
Question Optima 6V
What's fully charged for a Optima 6v? Is it 6.3v?
M2M is offline   Reply With Quote
Old 04-13-2019, 03:36 AM   #2
Werner
Werner's Avatar
Default Re: Optima 6V
7,2 Volt is max. load.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-13-2019, 10:26 AM   #3
Badpuppy
The Optima is just like any lead acid battery, except the plates are coiled rather than stacked, and it is sealed (SLA = Sealed Lead Acid). The nominal voltage at rest is 6.3V, 2.1V per cell. Optimum float voltage is 7.2V while charging.
Badpuppy is offline   Reply With Quote
Old 04-13-2019, 01:18 PM   #4
M2M
M2M's Avatar
Thanks.
Old 04-19-2019, 10:51 PM   #5
M2M
M2M's Avatar
Question Re: Optima 6V
I have a new Optima 6v question. I tried installing one using the holder shown below and with original type studs (that are not threaded in the middle) but it doesn't work...the battery sits too low so it cannot be held in place. Are you supposed to raise the height of the Optima (maybe with a piece of wood)? What's the solution?
Old 04-19-2019, 11:08 PM   #6
30 Closed Cab PU
Yes you have to raise them. What ever method that works.
30 Closed Cab PU is offline   Reply With Quote
Old 04-19-2019, 11:57 PM   #7
CWPASADENA
CWPASADENA's Avatar
How about using some spacers on the stud to get up to where the threads are.
Use some larger nuts as spacers or even a bunch of flat washers if you do not want to make sone spacers.
I do not like to put something under the battery to raise it up. It may loosen up and fall out while going down he road.
Just my opinion.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-20-2019, 10:01 AM   #8
duke36
Just my opinion.
Chris W.
Concur; we extended the threads with a die/cutting oil to accommodate the nuts..
duke36 is offline   Reply With Quote
Old 04-20-2019, 10:03 AM   #9
M2M
M2M's Avatar
Just my opinion.
Chris W.
I agree with you about not wanting to put anything under the battery.
Another option is to use the non-original studs (cut down threaded rod) MACS sells, see:
https://www.macsautoparts.com/ford_m...ent-style.html
Old 04-20-2019, 10:37 AM   #10
Benson
Benson's Avatar
PM Sent
Benson is offline   Reply With Quote
Old 04-20-2019, 05:14 PM   #11
d.
Bratton's sells the correctly shaped bracket to use an Optima in the original Model A battery holder; the bracket you picture looks incorrect for an Optima installation.
d. is offline   Reply With Quote
Old 04-21-2019, 01:06 AM   #12
M2M
M2M's Avatar
No, the bracket in my photo fits the Optima 6v fine and is sold by the other suppliers. With the Bratton's bracket is there still an issue with height when using original studs?
Old 04-21-2019, 06:21 AM   #13
Gastrap
Gastrap's Avatar
I bought the one in the photo and returned it right away. Quality was poor, and it could have shorted on the posts.
Now I have the oval shaped one from Brattons, and it looks good and fits. No spacer required.
Gastrap is offline   Reply With Quote
Old 04-21-2019, 05:38 PM   #14
d.
there's your answer.
Old 04-24-2019, 12:22 AM   #15
M2M
M2M's Avatar
Wish I knew all this before as it too late to return the one I purchased. It explains why the Bratton's one is more expensive...$25 vs $15.
Old 09-11-2022, 08:29 PM   #16
Lynn Wright
Lynn Wright's Avatar
I left the ignition switch on and my Optima 6V battery discharged down to almost zero. I have a 6vdc charger on it for 12 hours and it will only charge up to 3.5v. Is there a secret about charging this type battery, or does it need replaced?
Lynn Wright is offline   Reply With Quote
Old 09-11-2022, 09:55 PM   #17
eagle
eagle's Avatar
Parallel the battery to a working 6 volt battery. Charge both together, then charge the optima by itself. Use a set of jumper cables to parallel them.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-12-2022, 11:35 AM   #18
rotorwrench
rotorwrench's Avatar
You have to buy another model A to justify having two 6-volt batteries. You can't have too many model As.
Old 09-12-2022, 12:13 PM   #19
Lynn Wright
Great idea. However, I'll need to buy a 4-door so I'll have room to sleep.
Old 09-13-2022, 12:09 PM   #20
katy
katy's Avatar
I disagree, I always put a piece of 5/8" or 3/4" plywood, battery size, under the battery. That way the battery weight is spread out instead of it all being on that 1&1/2" or 2" strap.
