Old 02-28-2018, 04:22 PM   #1
kimeccles
kimeccles's Avatar
Default rumble seat step plate original?
I have been stripping a lot of paint off my step plate. The last layer after red, black, yellow, is sort of grey.
For judging how were these step plates originally? shiny aluminum? and if so how do I make it look good as mine are really dull looking like pot metal after all the years and stripping chemicals?
Thanks
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 02-28-2018, 09:33 PM   #2
700rpm
700rpm's Avatar
Default Re: rumble seat step plate original?
I shined up the aluminum trim on my 65 VW bus with 0000 wool. That might get you started. I don’t know what the original finish on the Model A step plates looked like, but most have seen look like dull aluminum, not shiny. The Judging Standards might tell you the proper finish.
Ray Horton, Portland, OR
700rpm is online now   Reply With Quote
Old 02-28-2018, 09:54 PM   #3
RandyinUtah
My 1930 Roadster came with step plates painted black. I stripped the paint off and was surprised that they were steel.
RandyinUtah is offline   Reply With Quote
Old 02-28-2018, 10:36 PM   #4
160B
160B's Avatar
RG&JS Section 15-14, and 15-15 revised 2016 attached for your info.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
