02-23-2018, 10:55 AM | #21 | |
Re: Engine install
Bill Loner
02-23-2018, 07:53 PM | #22 |
Re: Engine install
The engine and new transmission is in and happy. Thanks to all for your help. The alignment studs worked great.
02-23-2018, 08:40 PM | #23 |
Re: Engine install
Interesting thread. Would it make any difference if you had a multi disc clutch. The body is not off but the fuel tank is. My concern is lining up the clutch.
02-24-2018, 12:28 AM | #24 |
Re: Engine install
Bill Williamson, The reason I always install the engine in my own cars by myself is that to do otherwise would take too much of other peoples time. There was a time that I could install the engine alone in less than half a day. Now it takes me that long to find my tools. Since I passed 80, I have slowed some. I will help others but hesitate to get help on things I can do myself because of how slowly I work. And I may just find that I need a nap as well. Can't miss that if the ticker is out of sync. Been good the last several months since last time they electrocuted me and brought me back. All fun stuff as you know. I use jacks and lifts a lot now where I used to horse things that weighed less than 400 pounds. Now if it's 50 lbs. or more i use some device, other than my back, to get it where I want it. Much less painful I have found. I do enjoy working on the fool machines though.
02-24-2018, 06:29 AM | #25 | |
Re: Engine install
I've been "electrocuted" back to "normal"??? several times, each time I think, "Is this the time they TURN my LIGHTS OUT"???? Bill Highbeams
02-24-2018, 08:33 AM | #26 | |
Re: Engine install
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
02-24-2018, 02:08 PM | #27 |
Re: Engine install
I put them in and out as a unit several times. I can install one in a 1/2 a day
and I am 82 years young. Bill |
02-24-2018, 05:40 PM | #28 |
Re: Engine install
Daveymc29: in your avatar, you don’t look a day over 3
02-24-2018, 09:47 PM | #29 |
Re: Engine install
Do as a unit,don't stress the flywheel housing any more than you have too.Not a bad idea to check it for alignment to the crankshaft especially when installing such a nice transmission
02-27-2018, 10:32 PM | #30 | |
Re: Engine install
What's that panhard bar in that box? |
